Question about HP Compaq Presario v3000z Notebook
Motherboard compaq v3000
I am having a problem booting my system it boots to a black screen and the bios menu does not pop up.
None of these people know anything. lol@pagebor you have no clue bro. Anyhow Josh I did some research and it looks like you are going to have to get you gpu reballed. It seems to be a common problem with the v3000. Many other people have experienced the same thing. It is a really expensive procedure but you might be able to find a place that is like a specialty shop and just does that. Good Luck man
Posted on Nov 21, 2008
  • 105 Answers
Check the beep sound
1. Long beep for RAM is Unserviceable or not properly fitted. to solve this issue remove the RAM clean conducting area properly and fit it back. ( You restart the laptop without RAM and check fro long beep or same beep sound is coming)
2. Beep frequently for three times and stop for sometime and repeats then its video card propelem. Then you have to repair centre
3. Go throgh the manual for further beep description. Or goto manufacturer's site.
Posted on May 25, 2008
    Guru:
  • 859 Answers
The first device the bios loads is the graphics display adapter, this is so it can display the boot sequence or give you access to your bios setup screens. You must have an issue with your display adapter. You could first try attaching an external monitor, but you may have the same problem if you don't its related to the laptop mainboard communicating with your display adapter and the flat panel.
Display adapters on laptops are usually soldered onto the mainboard inside and cannot usually be removed and replaced. You would have to seek out a repair shop willing to work on your model laptop. If you are still under warranty seek service through your laptop manufacturer.
Hope this has helped or fixed ya.
Worldvet
Posted on May 16, 2008
    Genius:
  • 2,785 Answers
Resit your ram or try with another working ram,if the problem persits then try to boot through bootable cd
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
I have bought new boot disc or restore disc but it runs one cd then blue screen says discs wont work.it tells me to alt ctrl and delete then shows message that ntldr is missing.I know my compaq hp stores...
for setup the bios usually by pressing delete at first screen appear
or for some type motherboard is pressing F2 at first screen appear
after you at setup bios go to boot menu
the go to select boot menu and chose boot from cd for the first boot
then press f10 to save the bios setting and computer will restart
after restart isert your boot disc and if it ask to press any key to boot from cd press any key
then follow the instruction for install the operating system
Mar 04, 2011 | HP Compaq Presario SR5210NX Desktop PC...
I have a Compaq Presario v3000 tath i want to reset the bios
Simply tap DEL key when cold booting / enter BIOS and look for key that "Reset to default" in all panes located on RHS or base of screen. Repeat with all top panes.Reboot.
Mar 23, 2010 | HP Compaq nc6320 Notebook
When booting up the system avaratecscreen will
when the computer boots up try pushing the f8 key and see if windows will boot into safe mode. if not the try accessing the computers bios and see if the hard drive has crashed. the bios can be accessed sometimes by pushing the delete key during boot up or the access menu will be on the avaretec splash screen.
Nov 14, 2009 | Averatec (82-878011-01) Motherboard
How do i change the boot sequence. I have the Compaq sr1630- win xp os. Installed new hard drive after disk to disk copy. System has the Phoenix - Award Bios CMOS topman
During boot there should be a notifaction at the bottom of screen saying something like "Press Del for bios and F10 for boot menu" or something like that with other keys. If there is a boot menu option press the corresponding key and you will enter the boot menu. Here you can set the drive you want as first, second and depending on the motherboard third boot device.
If there is no boot menu option, enter the BIOS and go to advanced BIOS options, or something like that. There should be located a submenu called boot sequence, in which you can adjust the boot sequence too.
Jul 22, 2009 | Compaq Computers & Internet
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
Turn on goes to black screen
Can you access F10 bios - if you can access bios you have a hard disc failure - remove you hard drive - boot the system without the hdd and see if the pixie boot boot goes through - seen it before - your hdd is unservicable.
May 16, 2009 | Computers & Internet
Access BIOS
on compaqs the first screen usually will allow you to choose a boot device by pressing f11 you should then be able select the boot device.
this a black screen with icons at the bottom representing hdd floppy CD and network boot you move the cursor to select the appropriate boot device
Oct 17, 2008 | Compaq Presario 700 470024-192 Notebook
HOW TO BOOT
While your computer is booting up, when the manufacturers screen comes on, press and hold F2
Jan 28, 2008 | Compaq Presario X1000 Notebook
Won't boot up. Help!
could be a number of things, but first check the disc shaped CR2032 cmos battery located on the motherboard, in case it is flat. Then when the pc boots, you should get the cmos menu to enable you to alter the time and date. If still no boot, when it is booting press F8 and see if you can get to safe mode, and when in the menu select last known good configuration and press enter or a reboot. If you see no bios screen and the flashing cursor appears in the top left of the screen the cmos chip on the board is damaged, and the motherboard needs replacing.
Aug 16, 2007 | Compaq Presario 6010US (470027-054) PC...
HP Compaq Presario v3000z Notebook Logo
203 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
