Question about JVC GR D370US camcorder Mini DV
Camcorder is not switching on, not working on the mains either. Help...
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 07, 2010
I have a sony hdv 1080i camcorder. it works on mains power but will not work from a fully charged battery. Can anyone help suggest a solution?
Are these new batteries or old ones? If they are old it is possible that they will show as full but not have enough current to operate the device. If the batteries are over three years old or have been charged more that 300 times that is a distinct possibility. Also check the battery contacts on the device to make sure that they are not dirty. Clean with a pencil eraser.
Jan 10, 2015 | Sony HDR-FX7 Digital HDV 1080i High...
Panasonic camcorder playback and recording problem
We need more details on the problem,
Does the camcorder stay on, or it switches off , when the recording stops ?
Aug 30, 2008 | Panasonic NV-DS65 Mini DV Digital...
When I turn on the camera I get a white screen on hte monitor and nothing in the viewfinder. This occurs in the still, record and playback modes.
It sounds video processor is not getting voltage from sub power supply section on main board of camcorder that is why you do not get any video output in lcd or viewfinder in any mode.
I'm Sony camcorder tech and can help you if you are handy with electronics stuff repair and can take apart camcorder easily with proper tools.
In my opinion, there would be fuse blow out that provides volts to video signal section. Let me know exact model number of camcorder to proceed and if you feel uncomfortable working on camcorder then local camera repair shop is an option to get it fixed.
Hope these info will help you.
Thanks.
Nov 07, 2010 | Sony DCR-DVD301 DVD Camcorder
Camcorder not charging
Since the camcorder will power up and work with the charger connected, it sounds like the battery has died and will no longer hold a charge.
Feb 06, 2010 | JVC GR-D850 Mini DV Camcorder
Have not used it for some time. Have charged battery for a whole day and it still will not switch on? Any ideas?
when you hook the battery to the charger is the charged light comming on.have you a volt meter or a bulb [9 volt] to see if there is any charge in the battery.have you hooked up the camcorder using its mains tranformer to check that the camera is working? if so and it is you may have a circuit protector/fuse gone/blown internally.check the connections on the battery and the charger..hope this is of some help all the best farr64[colin]
Dec 29, 2009 | JVC Cybercam GR-DVP7 Mini DV Digital...
Can not finalize
Hi, Initially I had the same problem with the finalization process. But then i took off the battery pack and connected to the mains and immediately when i switched on the camcorder again, the ' Finalize ' button was highlighted i.e enabled. I continued with the finalization process and everything was fine. Was able to playback the mini dvd on a very cheap dvd player and also on a computer.
Also be sure to put the camcorder on play mode by sliding down the switch button to mode. You immediately notice that a little green button near play will light up
Jul 15, 2008 | Canon DC210 DVD Camcorder
Disk finalization error
dont know if youve found a solution already, but:
you cant finalzie the disc using battery power, you need to use the ac adaptor. This is something you should have got with the camcorder. its basically the charger plus another cable. so, plug in the charger to the mains as normal. then remove the battery from the camcorder, you'll notice a round hole in the camorder, this is where you plug in the cable i mentioned earlier, the other end of the cable goes into the same size hole found on the battery charger. that's it - you now have power to the camcorder from the mains. switch on the camcorder as normal and finalize the disk.
Jan 13, 2008 | Panasonic VDR-D100 DVD Camcorder
Battery Charge Light not working & can't display battery info
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Dec 29, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
NO POWER - TOTALLY DEAD!
i have the same problem . it sometimes comes on and just suddenly stops working . won't turn on whatever you do . and after a few days works again and it happens again . i love this cam and want to fix it .
Aug 27, 2007 | Panasonic NV-GS17 Mini DV Digital...
Camera won't power on from battery or power adaptor!
Water has got inside the camcorder. Dry it out gently in the airing cupboard for a week, then try again.
Mar 17, 2017 | Canon MVX150i Mini DV Digital Camcorder
Video Cameras Logo
22 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
