Question about Microsoft Xbox 360 Console
When I put a disk in, it says open tray, I put different disks in and its doing it to them also. My xbox will be 2 years old this xmas.
  • 225 Answers
Yep you need to stop the heat being taken by the sensors on the drive, you can use a good repair guide or send it in for a fix.
Posted on Sep 07, 2010
XBOX360 disk tray keeps ejecting
This is likely the same issue occurring when the disk tray will not open either. Suspect your drive belt is worn and requires servicing. This is best done by an xbox servicing agent. Not too expensive. I have been suffering with a tray that will not open for over 2 years now, however, I am able to fix it simply by ensuring a disk is always left in the tray. It only fails to open if there is no disk in the tray. Even then, I can open it by lifting slightly with a paperclip.
Jul 18, 2014 | Microsoft Xbox 360 Console
Xbox 360 Console: all works fine ubtil you put any disk in and the x...
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
May 17, 2010 | Microsoft Xbox 360 Console
Call of duty modern warfare 2. I put the disk in and it doesn't read it. It just says open the tray. All my other games work fine. This is the second disc of this game that I tried. It worked on the x box...
Try cleaning your drive with a dvd cleaner, and make sure the game disk is clean. Then turn off your xbox and unplug the power supply from the back of the console for about a minute or so. Plug back in and retry. Also try a different game like COD 4 or Halo, (both these games seem to be easier for 360's to read than some others. No scientiffic proof to support that, just seems to make a difference sometimes).
This works about 80% of the time for me, however it is likely that your dvd drive will need to be serviced in the future. If it doesn't work and your Xbox is under 3 years old call 1.800.4myxbox. Or if older than 3 years you can try to fix it yourself, there are a number of guids online for this. I personally like this one:
http://www.llamma.com/xbox/Repairs/cleaning_your_dvd_drive.htm
Good luck.
Mar 26, 2010 | Microsoft Xbox 360 Console
Does the area your xbox is in effect is reading procedure causing the open tray error? {mines by tv and has open tray error}
no , the open tray error is caused by any number of reasons and only when u open up the disk reader will u know which it is , ur i can buy a new disk reader and when it arives all u need 2 do is take out the chip of your old 1 and put it in the new 1 , there r great videos on u tube on how 2 do it.
Jan 13, 2010 | Microsoft Xbox 360 Console
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Mar 28, 2009 | Microsoft XBOX 360 ARCADE Console
Xbox 360: disk drive will get stuck...may be leading to disk not spinning
If you ever open the disk tray and then the power source is cut, the tray will try to ''autofix'' itself by making whatever state it was at the default position. This doesnt sound like whats going on for you, though.
If you can turn your 360 on and go to the main screen, try opening it with the ''open tray'' button on the bottom of the main screen.
If that fixes it, your problem is a faulty disk tray button.
If the tray still does that with the xbox main menu button, then its a mechanical thing with the tray.
Go to walmart and buy one of those air spray bottles (like an airsol can to clean dust out of PCs) and spray it into the 360 tray once it is opened. Aim the spray on the sides, what it sounds like is dust or something collected on the gears of the disc tray. If you have your 360 on carpet or a dusty surface this is probobly the problem.
Thats about the only thing you can do without opening the 360 up yourself (IF ITS STILL UNDER WARRANTY DONT OPEN IT) that will void the warranty. So if the airsol spray doesnt do it, then send it in to microsoft.
hope that solves it
-erk
Jun 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 Will Not Play Games....
Try opening the disk tray with the 360 off. 05a1ed9.jpg Push a paper clip into 1 of these holes in your 360. It will pop the tray out. Grab the tray pull it out all the way. Put a game in, leave it open! Then turn your 360 on see if it boots the game.
"Your Disk tray might be going bad. It might be fixable but I will have to try it out on a bad drive which iI dont have at this time."
Oct 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
