Question about Keurig Elite B40 Coffee Maker
My keurig won't turn on! HELP!!!! - Keurig Elite B40 Coffee Maker
Keurig won t turn on
This is a known problem with the Keurig and is actually addressed on their website. Problem With Your Keurig Coffee Brewer
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Jan 04, 2014 | Coffee Makers & Espresso Machines
Keurig B70 won't turn on
contact Keurig (866-901-BREW) for help.
Dec 26, 2012 | Keurig Platinum B70 Coffee Maker
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
My keurig is flashing NOT READY and AUTO OFF SET and won't brew or even turn off
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
My Keurig says not ready, water won't stop coming out. when it reads brewing, it stops.
heatman101
Jul 23, 2011 | Keurig B100 Coffee Maker
I ran a cycle of vinegar through special edition brewer and it continues to say de-scale after doing scaling. it won't pour water sometimes and has to be turned on and off to get it to pour water. ...
heatman101
Jun 14, 2011 | Keurig Platinum B70 Coffee Maker
My keurig won't heat up and the switch at the back won't go on or of
heatman101
May 26, 2011 | Keurig B70 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
4,660 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
