FixYa.com
Tags:
Acer Aspire 3610 PC Notebook
Acer aspire 3610
posted by big54bob on May 13, 2008
my cousin pluged the labtop in using a 15 volt plug and not a 12 what might he plowen and can it be fixed thank you and how much to fix it thank you bob email is big54bobs@yahoo.com thank you again
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 13, 2008
Thanks for Trying (70)
freetek
Rank:Wiz Wiz
Rating: 83%, 201 votes
Depending on the system and the supplied adaptor type, substituting another can result in damage.
Some adaptors (nearly all 'universal' or adjustable types) are very primative and have little or no regulation meaning that the output set and the output you actually get are highly load dependent and the actual output voltage can be 50% higher than set.
Most laptops use a somewhat better adaptor (more stable output) and have internal final regulation to service the unit's needs and charge the battery pack at the same time.
Using the wrong adaptor can seriously damage the unit's internal regulator and you may have already done that even though the stated voltage is only 3V or some 25% higher.
If the laptop no longer boots, you may have some expensive repairs ahead.
Rating Locked! (?) big54bob has rated this solution as Thanks for Trying
Can you Help with these PC Laptops problems?
Aspire 3610 Bios Password???
What was the fix for resetting... Answer This...
webcam..
hi! i just noticed this is for... Answer This...
dell 5100 laptop
power button must be pressed... Answer This...
Delete test videos in acer...
Being new to arcade deluxe, ran... Answer This...
crystal eye webcam
I just got a laptop acer... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
