Question about Amana Heating & Cooling
After cooling cycle compressor off but compressor fan still runs constant unless power is interupted
    Master:
    Sergeant:
  • 449 Answers
Check the fan relay is sticking and has to be replaced
Posted on Sep 09, 2010
We have a 2008 Dodge Grand Caravan. My question is: when the engine is running, does the radiator fan run constantly or intermittently?
electric fans start to operate when the coolant temp reaches around 88 c and will run continuously while the coolant is above that temp
if you have ac then there is a fan that cools the condenser in front of the radiator and that will cycle according to the ac compressor cycles
Jun 02, 2017 | Dodge Cars & Trucks
The cooling fan comes on five minutes after starting
Unless you have the A/C on, that may be normal. The cooling fans only run once the coolant temperature exceeds about 215 degrees. It runs until the temp is down to about 200 degrees. The fans will cycle on and off as necessary to keep the coolant within that range. When the car is in motion, the airflow thru the radiator is normally sufficient to keep the coolant stable and the fans do not run. Only if you turn on the A/C will the fans runs constantly, since the A/C system needs constant airflow thru the evaporator.
Nov 03, 2016 | Cars & Trucks
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Dometic roof ac will not cycle
check wiring and dip switches make sure fan on auto
Jun 14, 2012 | Dometic Rooftop RV Air Conditioner
The side door is getting hot
Pull the unit out away from the wall. Remove the bottom cardboard or metal cover that covers the compressor area. Assure that the compressor fan is working usually when the fan is not working the sides of the unit will start to heat. If the compressor fan is not working shut the unit off until the compressor cools. I have used a box fan while leaving the cover off on a unit to keep the compressor cooling while I had to wait for the new compressor fan motor to come in. DO NOT RUN THE REFRIGERATOR IF THE FAN IS NOT WORKING UNLESS YOU HAVE SOMETHING TO KEEP THE COMPRESSOR COOL like a fan constantly blowing on the compressor. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Sep 08, 2011 | Refrigerators
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Compressor cuts in and then cuts out
sounds like compressor is locked up or bad compressor start components or could be tripping on a high pressure switch is condenser clean? .T
Jun 17, 2009 | Danby Portable Air Conditioner
Clicking noise from compressor and fan runs 24/7
check the grounds to the ref. also check power to the ref. but it sounds like you have a floating ground the only thing else to mke comp.cycle is the relay which is on the comp. itself
Jan 08, 2008 | Kenmore 53092 / 53094 Side by Side...
Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Oct 13, 2007 | Refrigerators
Heating & Cooling Logo
44 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
