Question about Thorens TD-170 Turntable
Hi my Thoren TD 111 speed is slow please give advise. Thanks
What is the maximum speed ford galaxie ghia 4 cylinder 111 hp 1992
Hi, This is set at factory maximum speed & set into the vehicles computer. Please leave me feed back: Malcolm Campbell, Thanks
Oct 24, 2017 | Ford Cars & Trucks
Fuel filter rav4
toyota recall? call the dealer and give them the VIN
Mar 27, 2014 | 2002 Toyota RAV4
I just brought a Tp-link TD-w896ON but the internet speed 1.67 mbps ??
The line speed is controlled by your internet service provider, not by your router. If you have something like AT&T as your internet service provider, then they sell 3 or 4 different line speeds or packages. The cheapest will get you the slowest line speed. So if you have a 300mbps router but you purchased AT&T's cheapest line speed it will never allow you to do downloads, uploads or streams at 300mbps. You gotta Pay to Play. :)
Jun 02, 2012 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
I am using tp link td-w8901g router.my internet speed is of 384 kbps for which i have to be able to download at maximum 48 kbps. when i use internet normally, i am having slow browsing. the download speed...
If you are paying for a downlink speed of 384 Kbps you should be getting at lease around 300. First bypass your router - connect your cable/DSL ethernet line directly from the modem to your PC. Go to http://www.auditmypc.com/internet-speed-test.asp run the speed test and see what your download speed is.
If it's less than 300 call your service provider & ask them to check out your line. If they say that you are getting 300 Kbps or more, you have a problem with the ethernet card in your PC. Replace it.
Of course, if your speed is OK when you bypass the router, you have a router problem. Contact the manufacturer or replace it.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 30, 2011 | TP-LINK TD-W8901G Router
I have a Ricoh aficio 2018D problem is SC390 Code i reples PCU Unit Lower unit/Drum & Developer but sc390 code problem not solw. Please help Me.
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Ricoh Office Equipment & Supplies
Thorens TD-170 Turntable Logo
59 people viewed this question
Top Thorens Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
