Question about Intel DG31PR Motherboard
I get three beeps when I turn on the computer. I already bought new RAM and a new power supply and still the problem persists.
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: My motherboard BIOS is not starting
look for the CLRCMOS or CLR or JBAT1 terminals. These are the cmos settings and may need to be cleared, so refer to your motherboard manual for which one you have. Although what has probably happened is that when the PSU blew it may well have shorted the cmos chip which cannot be repaired, or damaged the graphics.
Posted on Apr 12, 2007
  • 43 Answers
SOURCE: no display
no display is basically ram issue but condition that mother give u beep noise,
refix RAM proprely, chaque SMPS , PROCCESSOR,HARD DISK, Fixed togethar again ok resolve issue.
Posted on Mar 17, 2010
ghello0805
  • 49 Answers
SOURCE: The computer turns on but does not boot, I get 3 long beeps
i think the problem was memory try to remove and clean it using pencil eraser. and back it properly..
Posted on Dec 01, 2011
Problem: No signal to desktop monitors
You have a hardware virus, on the motherboard sounds like and let me guess, do you use WMP windows media player, and also do you have a phone hotspot, if any of this is true, you have the same as I did, message me or comment now I am on line.
Mar 07, 2016 | Computers & Internet
I have rebuilt this computer several times. from the ground up. now I get 3 long persistant beeps. according the computer home .com is a video problem? is this true? Thank, Jack
PC generates three long beeps (1 Second Cycle three times then 2.5 Secondds Pause) when there is Memory (RAM) Error. Try inserting DIMMs again. Make sure that the timings (Clock Speed) of DIMMs are compatible (matches) with your motherboard.
Oct 03, 2015 | eMachines T1100 Motherboard Replacement...
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
I have a HP Pavilion dv6700 special/limited edition. I start it up, and all lights turn on and i can hear the computer is on. But the screen is black. And then I hear a beeping sound three times. First...
Hello
OK, depending on the bois version you have, the problem is either your ram modules, or your video card.
I will suggest that you start by taking out the ram module and see if the beeping persists.
If not, you will need to buy new ram.
Hope this can steer you in the right direction.
Click HERE to have a look at the solutions.
Kind regards
Andrea
Sep 09, 2010 | HP Pavilion dv9000z Notebook
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Monitor not responding to computer
better check the continuity of you cables/connectors.
May 28, 2009 | E-Machines eMachines Desktop PC
One Short beep and two long beep
The beeps you hear are BIOS Beep Codes. Sort of like a Morse code, if you know what that is. Every computer has it's own BIOS program, and version of that program. Each BIOS has it's own Beep Codes.
Taking a guess, as I don't know what BIOS program or version you have, it sounds like a ram memory issue.
Suggest you,
1.Unplug the computer
2.Open the computer case
3.TOUCH the metal frame of the open computer case, to relieve you body of Static electricity. Static will silently fry out your delicate computer hardware components. You won't see it or feel it.
4.Remove the ram stick/s. Reinstall the ram stick/s. (Stick/s means one ram stick, or two, three, or four ram sticks)
You may have just had a loose ram stick.
Apr 28, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Jan 18, 2009 | Acer Aspire T135 PC Desktop
Intel DG31PR Motherboard Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
