Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
The clutch is not mechanically engaging with the basket properly
  • 4 Answers
Undo the main bolt under the washer pull of the brake hub undew 5 0r 6 bolts and undo 2 plugs there are coil magnets i say about 20 clean them with air and use fine grit sandpaper on the end and inside the brake drum tri that it worked for me
Posted on Sep 22, 2010
Fisher and Paykel washer fault code 40. Is it possible to repair DIY. What to look for?
This is error code 40.
40. (00101000) Basket Dis-engage Fault
While carrying out a basket check, the Motor Control Module has found that the basket is
not engaged even though the pressure sensor indicates that the basket is empty. The
Motor Control Module continues to check for 2 minutes, after which time it displays this
fault. The first two areas to check are the clutch and the pressure tube. If these two
appear correct, then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing
the clutch from re-engaging. Excessive suds can stop the basket
rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
May 21, 2017 | Fisher and Paykel Washing Machines
Road king clutch wont' engage
Clutch discs worn out, pressure plate burned/worn out, diaphragm spring damaged or retaining screws loose or clutch adjustment or cable adjustment way out or basket/hub wear or release mechanism defective, bound up.
May 31, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
Code error 40
40. (00101000) Phase 1 to 6 - Bowl Dis-engage Fault
While carrying out a Basket check, the Motor Controller module has found that the
basket is not engaged even though the pressure sensor indicates that the Tub is
empty. The Motor Controller module continues to check for 2 minutes, after which
time it displays this fault. The first two areas to check are the clutch and the
pressure tube. If these two appear correct, then the fault could be in the pressure
sensor in the Motor Controller module.
Action:
1) Check that there are no clothes or other foreign objects preventing the clutch
from re-engaging. Excessive suds can stop the basket rotating.
2) If the machine is empty of water, carry out a clutch disassembly procedure
3) Next check that the pressure tube has not come off and that it is not kinked.
Secondary Source: Motor Controller module.(Display Module Phase 1)
Action:
Replace Motor Controller module
Mar 31, 2012 | Fisher and Paykel Washing Machines
Code error 40
Action:
Action:
Mar 31, 2012 | Fisher and Paykel GWL11 Top Load Washer
Clutch not engaging
could be a few different things,But always start with the small( inexpensive )first and work your way up...#1 check your clutch cable adjustment to be sure its engaging and disengaging properly(clutch cables stretch over time and need replaced or adjusted)...but if you have never done any clutch work to the bike(and you ride it like i do mine) #2. it probably needs new clutch plates and #3 maybe clutch basket from your description of the problem. the clutch plate fibers wear down over time(they are like brake pads and wear out).and the plates wear groves in the clutch basket and interfear with the plate movement...hopefully its just your cable..hope this helps..
Jul 30, 2010 | 2003 Suzuki RM 125
Thought i burnt the clutch out on my wr,at a recent t and t,the bike wouldnt move when in gear with the lever released,so i replaced the clutch plates and oil,i can start the bike ,put in gear,when i let...
Please pardon my response if it is too simple, but did you correctly align the pressure plate (Center part that tops the clutch plates and has springs bolted through it.) with the inner clutch basket (the part inside the clutch basket that the pressure plates spline onto)? If this is not aligned, the pressure plate will not fully engage the clutch plates. Both parts usually have an indicator mark that shows proper alignment.
Nov 09, 2009 | 2004 Yamaha WR 450 F
Clutch not egaging with basket for my profile harmony washer
If you are getting the message " The clutch is not mechanically engaging with the basket properly " the service manual says to check wiring connections, clutch motor or inverter board.
I rarely see a wiring issue. I'd check the clutch arm and clutch coupler too. They are nylon parts. I'll send you a couple pages from the service manual as soon as I get a chance to scan a few.
Nov 15, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony Clutch probs./Invertert PCB history
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Jul 30, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Won't Spin Without Assistance
It sounds to me like either there is an excessively heavy load in the washer and the unit simply isn't strong enough to get it going, or more likely the clutch mechanism/gearbox is malfunctioning. They use a clutch mechanism to allow the motor to run at a constant speed while the basket can start rotating slowly and pick up speed with time. If this clutch mechanism or gearbox isn't performing properly, the basket won't spin. It's not your motor or safety circuit since the basket will turn if given a little push.
Mar 10, 2008 | Washing Machines
A problem has been detected with this unit
Hi: Replace motor asm w/clutch part no. wh20x10024
 If you can put the washer to its side on the floor, check if the small white motor turns when you press start cicle.
Oct 01, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
139 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
