FixYa.com
Tags:
Microsoft Windows XP Professional
Computer problems
posted by nick981722 on May 13, 2008
I have pop up blocker on and all types of pop ups are popping up and I am unable to turn windows update on
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 13, 2008
Not Rated (0)
rickatnight1
Rank:Guru Guru
Rating: 85%, 41 votes
  1. Which pop-up blocker are you using? Internet Explorer 7 has its own pop-up blocker which I suspect you are talking about. If you have spyware on your computer you can still get popups. Download, install, and run Hitman Pro. This will run several anti-malware programs automatically for you and clean up almost anything hiding on your computer that could cause this.
  2. Malware can prevent you from updating Windows Update. After running Hitman Pro try it again. If you still can't then you may need to re-enable the Windows Update service. right-click on My Computer and select Manage. Expand the Services and Applications category on the left and select Services under it. On the right, find the Automatic Updates service and make sure that it is started. If not, right-click it and select Start.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
ErikO
Rank:Wiz Wiz
Rating: 87%, 15 votes
Popup blocker has three levels of strength, low, medium, and high.
In high, all pop ups are blocked, and if this is your desire, then open internet explorer, choose Tools / Pop up blocker settings / and toward the bottom of the screen you will see an option to set the pop up block level to 'high'.
If this is not the problem, and you still have pop-ups, then you most certainly have spyware / adware on your computer.
In this case download 'Spybot' (google for it), install, update, and 'scan for problems'. This is totally 'freeware', and will never cost you money.
Watch as it digs out severe problems from your computer and the pop-ups disappear.
Regards,
Erik.
Can you Help with these Operating Systems problems?
Operating Systems
vb programming
find the Furure value of an... Answer This...
Operating Systems
My Sandisk Sansa e250r keeps...
I have tried many things to fix... Answer This...
Alguien habla espa?ol?
No reconoce el micr?fono. Est?... Answer This...
microsoft works trying to print...
the printer is not short of ink... Answer This...
chanies mobile TV800 not...
chanies mobile TV800 not... Answer This...
Repair Service
Find Operating System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
