Question about Coleman Mach III Air Conditioner
Do I ever need to recharge my coleman mach 3 - Coleman Mach III Air Conditioner
    President:
  • 1,515 Answers
Hi, and the answer is no. This system is a sealed hermetic a/c unit, and does not require you to charge the unit, only if it develops a leak in a coil, copper line, or a line has rubbed through causing it to leak. If it is cooling good, your freon level should be fine. It doesn't hurt to go on top in the summer or before it gets hot, remove the cover and take your garden hose and kill power. Now, wash the coil out real good. They get very dirty and cause the pressures in the system to get real high and the unit will not cool like it should. This is about all you can do, but its very important. Keeping the indoor filter foam clean is also good, but no you don't need to charge it on a regular basis, only if you have a leak in the unit. Please don't forget to rate me as I know you will be kind. Please let me know if you have any problems with your unit, and I will be happy to help you out.
Sincerely,
Shastalaker7
A/C, Heating,
Posted on Sep 08, 2010
  • Frananderic Jun 11, 2011
    Awsome thanks! Was wondering how long the charge will last and when my unit is in the hot sun with no shade it cools ok but not like ice cold could there be a problem? And would my first step b to clean the coils? Thanks for the help
SOURCE: coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
Posted on Dec 31, 2008
koolbreezes
  • 540 Answers
SOURCE: coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
Posted on Aug 28, 2008
  • 587 Answers
SOURCE: coleman mach wire schematics?
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO
www.rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on May 11, 2009
  • 587 Answers
SOURCE: Just need appx. starting current
GO TO
www.rvcomfort.com
Posted on May 20, 2009
  • 92 Answers
SOURCE: can this unit be recharged
yes but you have to get a special tool to add a service port.
Posted on Jul 13, 2009
Why is campers inn saying I need to replace my Coleman Mach 3 with a Coleman Mach 8?
we would have no idea . perhaps if you contact Coleman they can tell you .
Feb 15, 2017 | Coleman Heating & Cooling
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
I am changing the 3 capasitors on a coleman mach and i need a wiring diagram
You may want to check the PPL parts superstore website as they have a good
parts diagram of the air conditioner. Although I only see one capacitor and it has
two leads.
Mar 01, 2011 | Coleman Mach 15 Air Conditioner
Need a schematic for Coleman 6759 mach 3
GO TO rvcomfort.com
Aug 20, 2009 | Coleman Mach III Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
My coleman mach 3 air conditioner will not come on at all I charged the battery and checked all the fuses and still nothing
GO TO
www.rvcomfort.com
May 10, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
Coleman Mach III Air Conditioner Logo
470 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
