Question about Onkyo TX-SR605 Receiver
Headphone Jack I am hearing impaired, my wife is not. Is there any way to use the head phone jack "without" muting the regular speakers. Access to back of box is extremely difficult....hoping you may have a suggestion.....Thanx.
  • 4,234 Answers
Unfortunately these units are designed to output to either the speakers or the headphones. There are devices available on the market that will take the output from the tape-out jacks and transmit it to a wireless headphone. I would suggest that you investigate this. That would also eliminate any wires stretching from the equipment.
Search the web for "assistive listening" devices.
Dan
Posted on May 14, 2008
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Hitachi 42 PMA400e Plasma Tv.
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
My denon 3808ci reciver has sound out put when you connect head phones but nothing coming out of the speakers when the head phones are disconnected?
hi,
In all receivers when you connect the headphone it will swich off the speakers. Its normal. When you use the headphone there is no need for external speakers its the principle behind this. .
ok
Sep 09, 2011 | Denon AVR 3808Ci Receiver
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
How can I mute the headphone jack on an Insignia 22" lcd TV? The remote control will mute the internal speakers but not anything plugged into the phone/headphone jack. Must I open up the TV and make an...
As an idea, I was thinking as I read your post, I thought that this would be an ideal application for a pair of "Wireless/Ired Headphones", you could plug these into the headphone socket, and then use these to hear your sounds, these units have a mute on board.
You could indeed wire it into, the unit going in through, the back of the, set. You could wire it up, but in reality, it would be better to use a third party device and that way would not compromise any warranty.
Jun 11, 2010 | Televison & Video
Headphone jack on 22 inch flat panel tv
You are on the wrong website for this type of inquiry. This is a self help website for the repair and use of manufactured products made for consumer use
Jun 27, 2017 | Televison & Video
Onkyo TX-SR605 Receiver Logo
208 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
