Question about Cakewalk Music Creator 4 for PC (787537064018)
My microphone only records on one side. how to i do fi it so both lines records instead of just rhe top one?
  • 396 Answers
Your microphone could be a mono or single channel pickup. Look at the microphone plug and count the isolators between the metal contacts, if you count one isolator and two contacts you have a mono microphone, or if you have two insulators and three contacts you have a stereo microphone. If your computer only has a mono microphone input you may have to use your line in on your computer. If your volume is weak and you get noise on your channel you may be required to use a microphone pre amp and plug the output into the line in jack. Last make sure your computer speaker mixer is set correctly for stereo.
Posted on Sep 07, 2010
Microphone Not Working!
If this is a microphone that connects to the 3.5 mm microphone jack, check that your microphone is connected to the Mic port (pink on the rear of a desktop). Make sure that the plug is fully seated. If you are using a front microphone jack on a desktop, try using the rear port (or vice versa). Next, if you have Windows, check that the audio input is set to Microphone, instead of Line In. (For Windows 7, this would be Start > Control Panel > Hardware and Sound > Manage Audio Devices (under Sound) and the recording tab.) Microphone should be your default device.
Next try uninstalling the audio driver and letting Windows reinstall the driver. Use the Device Manager (under Devices and Printers in the Hardware and Sound Control Panel). Expand the section labeled Sound, video and game controllers. Then right click on the Audio driver. Click on Uninstall then reboot the computer after the driver is removed. The correct driver should be reinstalled. (I believe that you do not have a separate driver for the microphone under Windows but you should make certain of that.) Check for driver updates as well. The Windows Update may list these as Optional updates.
If you have a USB microphone, try a different port. Also check for drivers from the manufacturer.
If you have an Apple or Unix OS, check for similar issues with the connection or drivers.
I hope this helps.
(who had a similar problem with Audacity recording on the line in port last month; I fixed the problem by uninstalling the audio driver and then reinstalling it. Then changing the Recording Source to Line In finished the fix. The driver got changed by a computer tune-up utility (registry cleaner).)
Apr 13, 2012 | Labtec Audio Players & Recorders
Which button is which
On the top of the device are the recording indicator and built-in microphone. On the front of the device to the right of the screen: (from top to bottom) ERASE, MENU, VOLUME UP, VOLUME DOWN
The MENU button cycles through these options in this order: Folder, record condition, record quality, AVR on/off, play condition, beep tone, set year/day/12 or time, key lock on/off
On the right side of the device: (from top to bottom) RECORD, STOP, PLAY, FORWARD*, REVERSE* *(FORWARD/REVERSE can be used in the MENU mode to select options)
On the left side of the device: (from top to bottom) External microphone jack Connects headphones
Here is an online (*.PDF format) manual for the recorder: MANUAL
I hope this information helps! :-)
Mar 06, 2011 | RCA RP5020 Digital Voice Recorder
My speakers work but my mic does not. I cant see any hardware for my mic
Note that the microphone is not listed individually in Device Manager because it works through your sound card. Perform the steps in the following sections in order, and then test to determine if your issue is resolved after each section.
NOTE: The microphone should be selected as the recording device in the Volume Control tool(sndvol32.exe).
To verify this, follow these steps:
Click Start, and then click Run.
  1. In the Open box, type sndvol32.exe, and then click OK.
  2. Click Properties on the Options menu.
  3. In the Adjust volume for box, click Recording.
  4. Click OK.
  5. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording. Check Your HardwareIf your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer. Sound Recorder
  1. Run the Sound Recorder tool: Windows 95Click Start, point to Programs, point to Accessories, point to Multimedia, and then click Sound Recorder. Windows 98Click Start, point to Programs, point to Accessories, point to Entertainment, and then click Sound Recorder.
  2. After Sound Recorder is running, click Record (the circle on the right side), and then speak into the microphone. If it is plugged into the correct jack, the line on the display should move up and down. If it does not move, sound is not making it through your microphone. If the line does move, press Stop, press Rewind, and then press Play to listen to your recording. If this works, but it does not work in your program, view the "Using the Microphone in Programs" section in this article.
  3. Still Cannot Record
If you cannot record a .wav file after you follow the steps in the previous section, there may be a problem with your microphone property settings. To check these settings:
  1. Double-click the Speaker icon on the taskbar, and then verify that the Microphone slider is at the top and that the Mute check box is not selected. If Mute is selected, click to clear the check box.
  2. Select Properties from the Options Menu. Select Recording and click OK. Verify that theSelected check box under Microphone is checked, and that the Microphone slider is at the top.
  3. Try recording a .wav file again.
Jan 19, 2011 | HP (400745-001) Sound Card
Headet and desktop microphone problem.
first check if you have the right drivers on your computer for your audio, if you have audio like mine go to realtek audio manager it should be right beside the clock, then click on the top right corner it says device advanced settings it opens another box that gives you options for recording like tie up same type of input jacks, ie. line-in or microphone,as an input device. and it has another one separate all input jacks as independent input devices you could try one of those if you have realtek audio manager theres other options to that might help and if you dont have that go to recording devices and see if your mic is working properly and if its set to default device
Apr 25, 2009 | Logitech USB Desktop Consumer Microphone
No Sound When Records are recorded to Computer via the Microphone
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
How to activate my builtin mocrophone
Dear
to activate builtin microphone do following step:-
1- double click on volume icon (right side down of ur desktop), Playback control window open.
2- In playback control window click on options>properties.
3- In properties windows u see "adjust volume for" area , here click on "recording".
4- while click on "recording" down u will see option for ur recording devices (Line In, Microphone,S/PDIF in etc ) select on microphone and click ok.
5- now u will see " Recording Control " window here select microphone and adjust volume for microphone
Ok now u will turn on ur Microphone Try to chat with anyone to ensure ur microphone is working.
Oct 22, 2008 | Dell Inspiron B130 Notebook
No sound coming through when recording from hi fi tape to computer
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
Jul 01, 2008 | Genius Soundmaker Value 5.1
Microphone does not record sound after connected to pc
Did you check the Device Manager to make sure the audio drivers are installed and the audio device is working fine?
Apart from that, the sound recording settings in Vista should be set correctly to select the mic as the audio input device (it might be set to "Line in" instead), and to set the recording levels high enough.
Jules
Oct 01, 2007 | Labtec Verse 524 Consumer Microphone
Cakewalk Music Creator 4 for PC (787537064018) Logo
613 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
