Question about HP LaserJet 3030 All-In-One Printer
How do I scan a bunch of originals from the tray and get 1 file for each page?
I want to feed 20 originals on my hp 3030 and get 1 scan per original without having to do it one by one.
    Sergeant:
  • 291 Answers
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
Posted on May 13, 2008
  • Daniel Martinez
    Daniel Martinez May 13, 2008
    Device does not pull media from the media input tray
    Is the device in manual feed mode?
    Try one of the following remedies:
    ● If Manual feed appears on the device control panel display, press MENU/ENTER to print the
    job.
    ● Make sure that the device is not in manual feed mode and print your job again.
    Is the pickup roller dirty or damaged?
    Contact a local HP authorized service provider. See Service and support for instructions.
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
How to scan images from the tray? I'm not sure if i know what you mean.
May 13, 2008 | HP LaserJet 3030 All-In-One Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
I got the manual for my J3680 all in one printer, BUT
Hello
It sounds like the scanner/fax is not seeing the original document that you want to scan or fax.
Per Page 20 of the User Manual, the original needs to be placed face down in the document feeder. (The document feeder is on the top of the printer, behind the display.)
When you insert the original, make sure the leading edge is sliding into the top of the printer (towards the front of the printer).
Per the user manual, you should hear a beep and/or see a message on the display stating the loaded pages were detected.
If you are not hearing the beep or seeing the message, your original is not loaded correctly - try sliding it further into the printer.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Apr 30, 2010 | HP J3680 Officejet All In One Printer
When I scan a document with my HP 3030 the file document is much larger than the original. Help!
What is your resolution set at? 100dpi would be 100%, 200DPI would be 200% and so on...
Apr 12, 2010 | HP LaserJet 3030 All-In-One Printer
It stopped faxing through the feeder and said feeder errror. its a HP j4680 all in one office jet
Hello, Brittany.
Give this a try (from HP Support):
Complete the following steps to check the condition of the paper, reload the original, and then open and close the Automatic Document Feeder cover.
The main reason for this issue is that the ADF rollers that pick up the papers might not grip the paper because dirt sticks to the rollers.
Step One: Check the paper and reload the original
The condition of the paper, or the amount of paper, might prevent the ADF from picking it up and feeding it through the product.
1. Make sure that the ADF tray contains fewer than 25 sheets of paper.
2. Make sure that the ADF tray contains no photo paper or carbon paper.
3. Make sure the paper in the ADF tray meets the following criteria:
* No curls, folds, creases, or tears
* No staples or clips attached
NOTE: Folded paper, torn paper, or paper with rough edges might not feed correctly. If your original is folded or damaged, either reprint the original or try to smooth out the damaged portions.
4. Reload your original, with the print side up, into the ADF tray. Place the pages so that the top edge of the document goes in first. Slide the paper into the ADF tray until you hear a beep or see a message on the display indicating that the loaded pages are detected.
* If still a problem, go to the next step.
Step Two: Open and close the ADF cover
NOTE: Remove all originals from the ADF tray before you open the ADF cover.
1. Open the ADF cover, and then close it again.
2. Press the OK button.
Follow these steps to turn the product off and then on again.
1. Press the Power button to turn off the product.
2. Wait 15 seconds.
3. Press the Power button to turn on the product.
Hope this helps.
Feb 26, 2010 | HP Office Equipment & Supplies
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
I have the officejet 6310 but cant use the scan feature, how do I get it to work
this is how you use the scanning features of your printer.
To use the scan features, the HP all-in-one and computer must be connected and turned on. The HP all-in-one software must also be installed and running on the computer prior to scanning. To verify that the HP all-in-one software is running, look for the HP all-in-one icon in the system tray at the lower-right side of the screen, near the time.
NOTE: Closing the HP Windows system tray icon can cause the HP all-in-one to lose some of its scan functionality and result in the No Connection error message. If this happens, you can restore full functionality by restarting the computer or by starting the HP Image Zone software.
For information about how to scan from the computer, and how to adjust, resize, rotate, crop, and sharpen scans, see the onscreen HP Image Zone Help that came with the software.
Scan an original
Follow these steps if the HP all-in-one is directly connected to a computer through a USB cable.
1.
Load the original face down on the right front corner of the glass.
2.
In the Scan area, press Scan To . The Scan To menu appears, listing destinations, including applications, for anything that is scanned. The default destination is whichever one was selected the last time this menu was used.
3.
To select an application to receive the scan, use the arrow buttons to highlight it and then press OK or Start Scan . A preview image of the scan appears in the HP Scan window on the computer.
4.
Make any edits to the preview image in the HP Scan window. When finished, click Accept . The HP all-in-one sends the scan to the selected application.
Send a scan to an HP Instant Share destination
1.
Load the original face down on the right-front corner of the glass or, if using the document feeder tray, in the document tray.
2.
Press Scan To on the control panel of the HP all-in-one. The Scan To menu displays.
3.
Use the Up Arrow and Down Arrow buttons to highlight HP Instant Share .
4.
Press OK or Start Scan to select the destination and scan the image. The image is scanned and sent to the selected destination.
NOTE: If an original is detected in the automatic document feeder, one or more pages are scanned. If no original is detected in the automatic document feeder, a single page is scanned from the scanner bed.
NOTE: For Windows users, the HP Image Zone software opens on the computer, and the HP Instant Share tab displays. A thumbnail of the scanned image will display in the Selection Tray. For more information on the HP Image Zone, see the onscreen HP Image Zone Help that came with the software.
Stop scanning
To stop scanning, press Cancel on the control panel.
May 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Office Jet 7310
chances are the feeder isnt feeding the paper at all, thats why you cant scan a single paper, try opening up the ADF and clean the feed rollers first, turn off the machine and gently rub the rollers again and again until you have a clean shot or surface, try this from thop to bottom rollers, please make sure though to insert uncreased paper and paper without eardogs on its leading edge, this could cause some delay upon feeding process
sometimes because it is exposed to dust, there is a tendency for the rolllers to slip, or you could be having a broken part that drives the feed rollers from your ADF.
Jun 30, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP LaserJet 3030 All-In-One Printer Logo
307 people viewed this question
Seeker5211
Seeker5211
