Question about StarTech.com Star TSP143, USB, Future Print Printer
My Star TSP100 printer has just stopped working. I've uninstalled and reinstalled the driver but keep getting an error message when I try to print.
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
Hi, My Star TSP100 printer always goes offline after computer shutdown
Hi Valued Star Customer
It seems like the USB host may be going into "sleep mode" and not awakening. Please contact Star Support at support@star-emea.com for documentation.
Best regards
Star Technical Support
Feb 13, 2012 | Star Micronics TSP100 Thermal Printer
Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
Trying to set up star tsp100 printer as a receipt printer on averasell pos software. Have installed the printer and it prints test page fine. However when I try and do an invoice on averasell the cashdraw...
... For windows 7 YOU MUST go to your printers properties and click the advanced tab and change it from PRINT SPOOL to PRINT DIRECTLY TO PRINTER...
and if you want your receipt to print off to the right size... install a second copy of the STAR TSP100 and set it as (COM3)... (make sure in the properties you change the paper size to 72 X receipt and cut to partial) i'd do it on both copies
as well go in to the virtual port config and add COM 3 and COM 4
then go to the averasel station properties and set cash drawer as com 4 with the generic/text printer and then under invoices set the print drivers as the star tsp100 copy (the one that is on com3)
and set the actual printer as Star Tsp100(the one that is usb)
sorry for the some what confusing step's perhaps someone else can word it better as i do not have the software in front of me right now...
but my end result was a cash drawer that opened
a printer that printed TO THE RIGHT SIZE and not a full page
Mar 28, 2011 | Star Micronics TSP 1000 Thermal Printer
My printer only prints to copies, want one Star TSP 100 future print, how do I change setting
It could be a setting in the driver or in your point of sale software. If you want to check the driver, right click on the TSP100 in Printers and Faxes and click on properties, then printing preferences and advanced. In advanced, make sure the copy count is set to 1.
If you need help assistance with Star Micronics printers, you can contact their technical support at (800) 782-7636 or http://www.starmicronics.com/Supports/TechnicalSupport.aspx .
Feb 17, 2011 | Star Micronics TSP100 Thermal Printer
Trying to use star sp200 with quickbooks pos and keep getting spread out printing
Sounds like the "template" is set for "letter size" paper rather than "receipt" paper.
Go to "Workstation" Preferences, and then "Printing". Verify the template selection.
Jan 07, 2010 | Matrix Star SP200 Receipt Printer
STAR TSP 100 FUTURE PRNT
check the roll of paper in the receipt printer. If it is feeding wrong, it will not print. Turn it around. Kathy
Jul 09, 2008 | Star Micronics TSP100 Thermal Printer
StarTech.com Star TSP143, USB, Future Print Printer Logo
130 people viewed this question
Top StarTech.com Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a StarTech.com Office Equipment and Supply Expert? Answer questions, earn points and help others
