Question about Sport & Outdoor - Others
Hi, The above Treadmill is displaying an error code of 'Er04' can you decode the fault for me?
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Hi, I have a commercial
Hi.
If there is incline fault, then the sensor must be calibrated. The error may happen even if you do not do anything. sensor goes out of calibration and you get e5.
The only reset you can do is by disconnecting power and removing console batteries if installed (that depends on the treadmill model).
I suggest contacting Techogim and following the procedure to calibrate the sensor. Contacts are listed at the right hand side of this page, click: Contact Us.
Posted on Sep 13, 2010
  • 20 Answers
SOURCE: Hi,when i start the treadmill
This error code can mean a few things. Here is a troubleshooting pdf
Posted on Feb 28, 2011
Healthstream Evo Treadmill. When I turn machine on, all I get is 3 Beeps. The screen display has 8 rows,The 6th row is fully on. The bottom the alpha numerals,the center led of each unit is also lit.
Sounds like a fault in in the treadmills computer system the beep3 are error alert sound meaning somethings has gone wrong inside or the motor is reporting jamb fault code etc and its displaying with the lights upon the display board an error code a treadmill enginer will understand
Jul 12, 2016 | Washing Machines
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Proform 6.75q Hi, I have bought the above treadmill off ebay but not yet collected it. The seller had said in moving it for collection the display no longer works, other than that still ok. Can this be...
Without the display you cannot use the treadmill properly.
Your guess in the cost to fix is good as mine as we don't know what caused the fault.
If it was me I would get my money back unless you can get it for a lot cheaper.
Mar 03, 2013 | Exercise & Fitness
Stairmaster quinton 612 plus error code e201
Quinton Error E201 Probable Cause Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
Corrective Action
  1. Use Up or Down arrows to bring grade into range.
  2. If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
Quinton Treadmill Error Codes E201
Mar 16, 2012 | Startrac Fitness Products Exercise &...
Corrective Action
Mar 16, 2012 | Exercise & Fitness
ERR on the treadmill when I switch on. how do I fix and get working
Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
Nov 16, 2011 | Kettler TX3 Folding Treadmill
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Error message reads: Pace error #1
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed.
These errors messages almost always indicate an upper console problem when they are consistently displayed. Failures causing these error messages to be displayed are rare.
If the error message is consistently displayed when the unit is powered up, the upper console should be replaced.
May 23, 2010 | Precor 9.21 Treadmill
I have four Treadmills of Stairmaster(clubtrack510), when I try to start the machine the error (1)ERROR CODE EPLO & (2)ERROR CODE E211 message I am getting please kindly help me how to over come these...
I will start from your Question 2 than Question 1 :)
Now,
Error 211 - Clear the error by pressing Power or Clear. Attempt to operate the treadmill again. If error persists, replace VSD or grade motor. Belt and display may continue to be used during Fault conditions by pressing Clear.
Error EPLO - It refers to an electrical problem or might be a Blown Fuse.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Error Code 63 on Phillips Plasma - what does it mean?
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
