Back to:
Tags:
Operating Systems
Generic problem for all Operating Systems
Upgraded 98 to me
posted by krisb2 on May 13, 2008
I have a Dell Inspirion, I tried to upgrade from my 98 to ME and yes should not have done it. so now when i go to boot up it will not boot up fully all i get is my desktop background and mouse no buttons icons anything so can not do a single thing. i have rebooted several times with no change still not able to get anywhere. I hate to lose all my files and pictures any idea on how to fix easily?? Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 13, 2008
Not Rated (0)
rickatnight1
Rank:Guru Guru
Rating: 88%, 55 votes
I would highly recommend using Windows 2000 than Windows ME. Press Ctrl+Alt+Del to load the Task Manager and see if "explorer.exe" is listed. If so, select it and press the End Task button. Then click File->New Task and type "explorer.exe" into the new window without the quotes. Press OK and see if it will load.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on upgraded 98 to me:
I don't want to Accept this solution
Solution #2
Not Rated (0)
ErikO
Rank:Wiz Wiz
Rating: 85%, 17 votes
Ok, it is far-reaching to attempt to repair your computer via this text box, but your files are NOT LOST. Simply purchase an external hard drive caddie, mount the hard drive inside it, and plug it into the USB port of another computer.
Now you simply drag n drop your precious data onto another computer.
Then you can go back and re-try your Me installation again, without any fear of losing your files.
Regards,
Erik.
Thank You!
Can you Help with these Operating Systems problems?
Microsoft Windows Vista Ultimate Edition
I have had this problem since I was forced to upgrade to...
how i install novatel merlin c201 card in vista
Operating Systems
i have a comp model trust item nr 13405 and i forgat my...
Operating Systems
i need help getting into my company direct defenders...
Operating Systems
Write Snake Game using Swings.
Loading problems.
Repair Service
Find Operating System Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
