From my sony camcorder hard drive when connected to my pc I cannot download pictures to a disc. Get a no track found msg.
  • genebo865 Sep 07, 2010
    Somewhat pc illiterate when it comes to motherboards etc. I guess that I need to go into the controller, find the model # on the MBrd, then google this number and then update bios?I'm not sure. It's probably pretty funny, but I'm fairly lost.
    President:
  • 4,070 Answers
Hi! You may need to update the bios of the motherboard for the usb to read the SONY CAMCORDER. Just go to the search browser then type the model of your motherboard then add bios update in the end. This may resolve the problem. Hope this helps and thank you for using FixYa!
Posted on Sep 07, 2010
  • dj_relly999
    dj_relly999 Sep 08, 2010
    Actually you are right, that's the best thing to do... don't worry doing this won't harm you.
Sony vaio vgn series laptop - when xp os loading blue screen appears and display the msg hard disk drive not detected.
system not found in my experience generally leads to a damaged or loose hard drive, try to open the cover at the bottom side of the machine, and reseat the hard drive, if it still says system not found, get a 2.5 inch drive case, put your laptop drive in the case and connect it to another machine, if you can access the drive great! save all your files and once complete return the drive to your machine and try to reinstall the OS from a dvd then reinstall your files.. and if still having the same problem replace hard drive thanks.
Oct 26, 2010 | Sony VAIO VGN-NS135E/S Notebook PC
I have a Sony Handycam TRV325E. I've lost the
if your computer is running windows vista or 7.forget the software.if you have win xp i don't think it's economical to buy the disc.why don't you just download the usb driver from this website:
http://www.sonydigital-link.com/dime/camcorders/sd/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV325E
with the driver installed you can get the PC communicate with the camcorder so you can get your pictures from a memory stick to import to your PC. now with videos, that would have to go a different route and you don't need the software for that.the video import would have to go through the dv (ilink or ieee1394) out jack from the camcorder to an ieee1394 port in your PC.your computer should have the required ieee1394 card installed and enabled.if you do it should then be a plug-and-play connection.all you would need is a compatible dv cable compatible with both cam and PC and a video capturing application like windows moviemaker to import your files of the tape.see p.209 of manual fig.59. hope this helps.thanks:)
Apr 09, 2010 | Sony Video Cameras
Hello, my Sony handycam model no is DCR-SR200 HDD. I can record, replay in handycam. but unable to download/copy the files into my PC. unable to read the memory in the CAM hard disc. please help me. how...
when you connect to PC if you can see the disk/camcorder drive in my computer, copy entire folders to your PC it will work.
possible : Check /replace USB cable
:without using sony software copy files from my computer.
:if lcd not working, use the copy button from the camera docking unit
Nov 29, 2009 | Sony Handycam DCR-SR200 Camcorder
I have lost the driver disc for Everio HDD
connect vcam to pc via usb cable: then copy thru windows explorer
on pc bottom left: click START>>then click My Computer; win explorer opens
on the right portion you'll see>> Hard Disk Drives, etc.;
then >>Devices with Removable Storage- the location where most probably you'll find your >>hdd vcam- w/some ID- brand?
Double click on it, locate your video/picture files and copy/paste to >> my Documents/my videos (my pictures?) located above Hard Disk Drives.
Import the desired video files to video editing software
Jul 25, 2009 | JVC Everio GZ-MG335 HDD Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony Mavica CD1000 download pic's to Vista sysyem
It seems like the only solution is to find a "disc recovery" program to pull the pictures off the CD. I found and bought ($39.00) the program CDRoller. Although it is designed to recover problem files I found it sees the pictures and allows you to move them to your PC hard drive. Take the unfinalized CD, put it in you CD drive and run CDRoller. It finds the DCIM folder. You can open it to get the folder that contains the pictures. Open it and all of your picture file names are displayed. You can select all and do a save. It will ask you where you want to save them and define the folder on your PC. When the save is done your pictures are on the PC and your disc is still unfinalized so you can put it back into your camera and continue to take pictures.
Dec 01, 2008 | Sony Mavica MVC-CD1000 Digital Camera
Downloading contents of hard drive from camcorder on to a disc
no sound suggests
  • a codec issue, check the manual for the device to find what it uses to encode its dv, and install the same codec on the pc, and it will play, often available from the makers website in FAQ
  • or the mic was turned off during record
Jul 12, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Sony DCR DVD602E
Found this website with lots of frequently asked questions re DCR-DVD602E. Might help.
http://www.sony-asia.com/support/faq/10878/productcategory/cam+hd+avchd+dvd/modelfirst?site=hp_en_AP_i
Aug 10, 2007 | Sony DCR-DVD602E DVD Camcorder
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
