Question about Car Audio & Video
Installing CD Player in Van
What do I need as a transition wiring harness to go from a 2000 Ford Econoline van (original equipment) with 6 speakers, to a Sony CDX-GT320 FM/AM CD player?
Thanks!
Tom
  • 3 Answers
Theres a harness you can buy to bye-pass the premium sound unit at theback of the van or you can just hardwore it and run new speaker, power and ground lines from the back to the dash. its cheaper but a litte more work. i dont know the naeof the harness or model number or anything but i do have one. Feel free to email me if you cant figure it out and ill dig the harness out for you.
wellgood04@yahoo.com
Posted on May 14, 2008
1997 E250 ford van radio wiring diagram color code
1997 Ford Econoline Van Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 8? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
This info came from website: http://www.modifiedlife.com/1997-ford-econoline-van-car-radio-wiring-diagram/ ----I used this site for my 01 grand marquis, and it was accurate.
Jun 02, 2011 | Ford E-250 Cars & Trucks
HOW TO INSTALL SERPENTINE BELT ON 87 FORD VAN
For the 1987 Ford Econoline Van:
Size Engine??
Engine Options (AC/No AC)??
Click on the following direct, Free Link. It has the Serpentine Belt Diagram for your 1987 Ford Econoline Van depending on your size Engine and Engine Options.
Let me know if this helped....
http://www.2carpros.com/car_repair_information/year/1987/make/ford/model/econoline/1987_ford_econoline_drive_belt_routing_diagram.htm
Apr 14, 2010 | 1987 Ford Econoline
How am I able to test an Idle Air Control Valve for a 2000 Ford Econoline Universal Van E-150 5.4L?
if you go to the trouble to remove it id suggest installing a new one if the van is idling incorrectly or abnormally high it may be faulty
Jan 19, 2010 | 2000 Ford Econoline
Radio wiring harness color code for ford van e-250
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black/Gray
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Oct 09, 2009 | 2005 Ford Econoline Cutaway
1988econoline van changed tempaturesensor no power too harness
try checking the fuel pressure if the van runs at idle you should have between 30 t0 45 psi anything more check the fuel pressure regulator
Apr 06, 2009 | 1988 Ford Econoline
Installing a cd deck into car
BUY THE HARNESS ON WALM MART IS GOING TO BE MORE EASY IS ON THE CAR ACCESORIES DEPARTMENT
Mar 18, 2009 | JVC KD-G120 CD Player
Changed the gear box on the ford transit van
did you reset the computer after replacing it?
remove the positive battery cable for 10 mins.....
Nov 15, 2008 | 2000 Ford Expedition
Installing a mp3 player in a 1989 toyota hiace van
go to pepboys or any place they sell car radios you can purchase an adapter harness that will plug into your factory wire harness that will give you a list of the wires to make the job simple the harness cost about 5 or 10 bucks good luck....
Sep 07, 2008 | Sony Xplod CD Player w/MP3 Playback...
VAN AUTO HOOK UP KD-HDR1
This radio can not use a common ground. If your speakers are all grounded together you will blow up the amp IC in the radio. The negative speaker wires run at about 6 or 7 volts and so do the positive speaker wires.
Trust me, run new speaker wires, do not common ground any of these speakers
If this was helpful a good rating would be appreciated.
Mar 08, 2008 | JVC KD-HDR1 CD Player
Car Audio & Video Logo
165 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
