Question about Kenmore Washing Machines
My washer continues to leak hot water in the tub when its not running and the temp is set on cold any ideas ?
  • 347 Answers
Water is leaking past the hot water fill valve solenoid .The only repair is to replace the fill valve assy. (hot and cold) this is not a hard repair to do......
Posted on Sep 07, 2010
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Water filling tub
You need a new cold inlet valve fitting.
Dec 08, 2008 | Kenmore 44042 Front Load Washer
Water level switch doesn't shut off the water
Washer Basics: Filling with water:
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Whirlpool Wahser top loader
possibly cold water should be running into the tub at the same time as the cold to regulate the temp.by only having the hot on, it could possibly have timed out and while still being short of water
Jul 08, 2008 | Whirlpool LSB6200KQ Top Load Washer
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
