Question about Kohler 12 kW Emergency Power System - 12RES-L
Have Kohler 12RES. Gives a CC1 code thenan OC code. Have checked out the starter, it's OK, have cleaned all ground cables and connections and had the battery tested it's OK. Where do I go next?
I don't have the solution I need one my generator has been unhooked from the load and still the same problem cc1 oc
please help thanks dave
lochlinservices@hotmail.ca
Posted on Dec 22, 2013
Check your load wires there probaly reversed. I had the same problem friday. The week before the electrican wired it. did the same cc1 then oc. had a generator company come out it was the wireing. my load and netural were reversed.
Posted on Sep 20, 2010
The starter on the 12res Kohler generator just hums (spinning sound). It doesn't engage the flywheel. Do I need a new starter?
OC is over crank failed to start. It will normally try 3 times before giving this error. You need to disconnect the battery and remove the starter motor, make sure it is free to move / spin. Either the starter has seized or the engine has siezed. Make sure the engine is free to rotate also, once you remove the starter you will see the engine flywheel there, removing the spark plugs will make it easier to rotate the engine. I would guess it is more the starter.
Jan 06, 2014 | Kohler 12 kW Emergency Power System -...
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
Generator won't start. Screen showing OC.
OC means OVERCRANK safety circuit stopped the auto start-up so you wouldn't burn up the starter. There is a reason the generator didn't start. Low battery, not enough fuel pressure, clogged air filter, bad starter... You just have to eliminate as many as you can visually. Rebooting the generator should clear the OC condition and you can try to start it manually.
Oct 11, 2010 | Kohler 12 kW Emergency Power System -...
12RES GEN.NAT.GAS FAILS TO START BY STRT BTTN AND TRNSFR SW
If the succession is 3-5 sec crank - 3-10 sec pause, it is OK, but the cranking is not successful (the reason should be investigated).
If the succession is more rapid 1 - 2 sec you may have bad PCB control.
Jun 03, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RES, 12.5kw genset. Less than a
check connections on speedsensor or take down rpms must be a screw or bolt on de fuelpump
Jan 25, 2010 | Kohler 12 kW Emergency Power System -...
When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Nov 11, 2009 | Kohler 12 kW Emergency Power System -...
Kohler 12 kW Emergency Power System - 12RES-L Logo
1,310 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
