Amano pix 3000x timeclock only prints 2 characters
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Because the battery is low.... www.gatewaytime.com Amano PIX3000x Ni Cad Battery AJR 111000
Posted on Oct 11, 2014
2 Suggested Answers
greg_margo
  • 1959 Answers
SOURCE: need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Posted on Apr 16, 2009
AMANO PIX 55 WHY WONT IT PRINT TIME IT ONLY PRINTS DATE
MAYBE IT DOESN'T LIKE BEING SHOUTED AT - AND NEITHER DO WE.
If you look in the manual, and correlate the instructions contained therein with the myriad menu settings controlling every aspect of the camera's function, I'm sure you'll be able to figure it out, in time.
Dec 04, 2017 | Pix Cameras
Why do minutes do not print?
The minutes do not print for one of these reasons.
1. It is not programmed to print the minutes (it may be programmed for a message, date, year, or other characters.)
2. The Ink ribbon is out of ink. Amano PIX Series Ink Ribbon CE 315151
3. The printer is either out of alignment or needs service
4. The Battery is low/dead.
www.gatewayitme.com
Jun 06, 2014 | Amano Pix-55 Time Clock
Amano pix-55 battery replacement how to
The Pix-55 has a simple CR-2032 coin battery. But the battery contacts are pin-point spot welded to positive and negative faces instead of being easily replaceable as they should be. I carefully broke the battery loose and soldered the leads from a single CR-2032 coin battery holder I got off Ebay, The green electronics board is marked +&- so easy to get the leads right. Before I started, mine didn't work at all and after the new battery it works great. What a shame many of these are probably thrown away because of a $2.50 battery. The next time mine goes bad I can easily replace it.
Feb 14, 2014 | Amano Pix-55 Time Clock
AMANO MJR 8000 print problem
it needs to be serviced. try www.gatewaytime.com
Jan 17, 2014 | Compatible 12 packs - Amano MJR 7000 /...
Amano MJR 8000 cuts off top of numbers on timecards
this is caused most likely by one of two issues:
1. The ribbon guide is misaligned or bent
2. A print needle within the printer is stuck or broken.
Try www.gatewaytime.com they offer affordable time clock service and parts.
Open time clock without key
use a screwdriver, but you may break the case. or get a key here.... www.gatewaytime.com
Dec 20, 2013 | Amano PIX-55/A180 Electronic Time Clock
THE TIME IS NOT PRINTING RIGHT ON THE CARD. THERE IS A LINE MISSING
A line is through the print because a needle within the dot-matrix printer is broken or stuck within the printer. This will eventually get stuck on the ribbon and tear a hole in the ribbon...and eventually led to complete printer failure. This can be caused by the running a staple or paper clip through the printer, yanking the card out of the clock while it is still printing or after years of lint build up (they are suppose to be maintained at least once a year). Try www.gatewaytime.com for an afforable replacemnt Gateway Time Systems Time Clock Sales and Service Pittsburgh
Sep 26, 2013 | Amano Pix-55 Time Clock
NEED REPLACEMENT DISPLAY SCREEN ON AMANO PIX-55
Try www.gatewaytime.com they are an Amano dealer with affordable prices.
Jan 02, 2013 | Amano Pix-55 Time Clock
237 people viewed this question
jasbo
jasbo
