If copies / printing is creating streaks or blotches, the corona wire may be dirty.
Here's how to clean the corona wire:
Note: If you have an alternate paper tray, lower that first.
1. Open the side cover.
2. Remove the green corona wire cleaner from inside the machine (near the front corner of the machine).
3. Insert the corona wire cleaner into the corona wire unit.
4. Wipe the corona wire with the corona cleaning tool, by sliding it back and forth across the corona wire slowly and carefully.
5. Replace the cleaner and close the side cover.
This should resolve your problem.
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
The corona wire was one of the first things I tried. It actually had a build-up of toner on one side after the cartridge switch.
And ErikO you were right. I made a couple of calls and it does look like the drum. The drum was remanufactured so the copy count is inaccurate. The machine is a workhorse so I really can't complain.
Thank you!
smudge on copies
