Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
I scan with SmarThru4 and the error message always shows that "device is busy, switch off and warm up again, later try again". I already switch on and off, warm up several times but it always show the error message. After warm up, "Scanner error" shown on the small screen of printer. What should I do?
  • 360 Answers
Helllo you have to replace new toner
Posted on Sep 08, 2010
HP LaserJet 400 colorMFP M475dw + Scan to Email + Device is busy, Try again later
If I'm getting this right, your printer says "Device is busy, Try again later" when you try to Scan to Email ? Make sure your Scan to email-configuration is set up correct. Still no luck ? Leave the printer without power for 30 min. You can also try a factory reset. If nothing help, check if your printer is still under warranty HERE. If still warranty call your local HP support and ask for service.
Nov 04, 2013 | HP LaserJet Pro 400 color MFP M475dw -...
When I try to scan, I get the error message that is is still warming up. This message will not go away. When I press other buttons it says 'busy', then back to 'warming up'. How can I fix this?
Try power cycling both devices.
  • Completely shut down the computer.
  • Turn off the printer.
  • Unplug the power chord at the back of the printer.
  • Turn on the computer.
  • Plug the power cable back in.
  • Turn on the printer.
If your still having issues w/ it. contact your manufacturer.
Good Luck :)
Feb 06, 2011 | Office Equipment & Supplies
After I turn it on it shows an error messaje
there are problem in scanner assembly. please clean care fully and properly of your scaner unit.,than its ok.,
May 10, 2010 | HP Laserjet M2727nf Multifunction Printer
Device is busy error
Check on the bottom right of the screen you will see a small printer icon.
Double click on the icon. That will open up the Print Queue.
Look at the print jobs. If one job shows as Spooling, click on the job and then delete it.
Don
Jan 18, 2010 | Lexmark Office Equipment & Supplies
Error message Vista Fax setup
Right Click on My Computer icon and go to manage. Go to event viewer and under the System (and also Application) categories, check for errors.
In the same window, go to Local Users and Groups->Users->Your user profile->Member Of and check whether you have sufficient rights(are you an Admin???), then go to Seervices and check whether the Service can be started in your profile.
Thanks.
Good Luck.
If the solution is helpful, please rate the answer kindly.
from
Jul 06, 2009 | Computers & Internet
Hp laserjet m1522nf
Copy function was not working, says "device is busy". Message appeared on the printer screen is:"scanner error 5, turn off then on". This was done several times and message still appeared. I called 866-625-1176 and was connected with HP Technical Support and after 20 - 25 minutes of diagnostics, the technician informed me that they were sending me a new printer at no charge. I assume this meant that HP is aware of the defect and has no solution other than to replace it. The printer was only 6 months old.
Sep 05, 2008 | Office Equipment & Supplies
My printer wont print - it had a staple in a page that was put into the paper stack. it is showing message check print cartridge - I have taken both out and put both back, but it wont change from that...
You steered me to getting two new cartridges. That worked, the error message stopped after I loaded the new cartridges AND turned the machine off, then on again. It worked after that.
cheers
Jul 31, 2008 | HP Office Equipment & Supplies
Hp 1310 printer
my printer is not update and not scaning andnot found scan shortcut
Jul 14, 2008 | Office Equipment & Supplies
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
301 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
