SOURCE: SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
SOURCE: Sony bravia KDL-S40A12U user manual
Have you tried support at Sony's website or typing in your question at google?
SOURCE: sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
SOURCE: Where can I download a
You can try this website
http://www.retrevo.com/samples/TV-manuals.html
They have manuals for all makes and models. You can always go to http://www.samsung.com/us/support/ and it will give you a phone number or you can sen an e-mail directly from that site. Good luck
Testimonial: "Brilliant advice. Solved my problem immediately. Many thanks."
