Question about Gaggia Baby Espresso Machine
Hi, Got a Gaggia baby class just replaced steam micro switch (broken spring in sealed unit) Checked wiring and reassembled. Steam now producing 100% but on switiching on brew cycle no water is coming from brew head. After pump has been running for a couple of seconds it starts to labour. Just like when you put a blind disc in when back flushing. This happends when heater light comes on, when the heater light goes off water begins to flow until heater light comes on again. This seems to point to a wiring issue but i have checked every thing i have done. Any help please guys and girls?
SOURCE: Operating instructions
Look on the website of www.coffeeitalia.co.uk They have manuals for most machines to download, Or try gaggia website.
Posted on Dec 28, 2008
  • 5 Answers
SOURCE: problem with steam
I'll take the machine if you are throwing it away:) You have a blown fuse. There are 2 fuses inside the mahine. Uplug the mahine, Pull the top of and locate both fuses. Connect a wire going from one end to the other of the fuse. This will temporarily short circuit the fuse. Now plug the machine in, and test it out. If it works, than that is obviously the bad fuse. If not, try the exact same procedure on the other fuse. My thermal fuse went out and it only set me back $1.98 to fix. Good Luck!
Posted on Jan 14, 2009
EsWorld
  • 1618 Answers
SOURCE: no water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Posted on Jun 19, 2009
EsWorld
  • 1618 Answers
SOURCE: Baby Gaggia making a bitter brew, help!
Have you tried backwashing, then removing the shower and screen from the grouphead to make sure that there is no coffee buildup on the screen.
As for the leak around the portafilter, the group gasket needs to be replaced,
Posted on Jul 03, 2009
EsWorld
  • 1618 Answers
SOURCE: The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Posted on Jul 15, 2009
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Doesn't produce steam out of the steam wand for more than 1 min.
Hi.
That sounds like you have a bad steam thermostat. You can replace that your self. Its the thermostat on the top of the boiler.
The other one is on the side.
Jun 29, 2009 | Gaggia Titanium Espresso Machine
Gaggia Deluxe - Excessive steam discharging into filter holder
your seal of non teturn valve of group, just above metal part where you put upper filter. open the valve and carefuly clean, check the seal and spring.
Mar 09, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Steam not working
i dont know your location, but you can check this sites mentioned above:
www.oemmeci.it
www.nuovaricambi.it
or you can check in car parts shops at your location, you should look at parts> sealings for brake pipes.... you request the sealing from rubber named VITON or SILICON.
Feb 28, 2009 | Gaggia Classic Espresso Machine
Problem with steam
Jan 05, 2009 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
87 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
