Question about Raymarine Raystar 120 GPS Receiver
I have a Raystar 120 antenae installed in 2002. The last couple years it keeps loosing fix. It is worst when I start up the boat on a damp morning but can happen any time
    Genius:
  • 1,478 Answers
If you have the Raystar 120 GPS antennae, it's time to replace it with the Raystar 125. The 120 is not compatible or upgradeable to/with the new GPS satellites. Contact Raystar for the upgrade.
Nevertheless, try rebooting it the next time it looses the fix. Pushing the Restart does not reboot it. You have to turn off the power to the antenna and then add power back to reboot it. This almost always fixes the problem.
Take care.
Posted on Sep 07, 2010
My GPS Raymarine (installed in 2001) with Raytheon Raystar 120 antenna indicate offen a NO FIX. A technician tells me that there must be a problem with the antenna and that the best solution is to...
Before you buy a new one if that is a raytheon raystar unit there is a lithium battery inside the unit check that first thats all you may have to replace.
Sep 04, 2010 | Raymarine Raystar 120 GPS Receiver
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
My Raystar 120 GPS keeps losing its fix.... the fix comes b ack a few minutes later, but then i lose it again. I have tried a cold restart, but the problem persists. Ideas?
Guys, most likely the litium battery is eol. Buy a new litium 3 volts battery for 3-4 euro's with soldering points . Use a pair of scissors, note the plus and minus side of the poles and carefully cut out the battery leaving enough metal to solder a replacement battery. Solder the replacement battery, and the problem is fixed. You're ready for another 6 years of fun saving 300 USD for a new GPS!
Oct 10, 2009 | Raymarine Raystar 120 GPS Receiver
Yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Aug 27, 2009 | Northstar 6000I GPS Receiver
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dim dashboard lights and problem starting
Could be a loose or dirty battery connection, poor battery, or alternator. Check all the cables and connections to your starter. Clean your battery posts. Have your alternator and battery checked. It sounds like you are either running off just the battery or just the alternator. One of them is not right.
Jun 11, 2009 | 2002 Toyota Camry
Problem getting a proper fix
The antenna should be replace by raystar 125.
Regards
Michel
May 31, 2009 | Raymarine RL70CRC GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
No transmit or recive but works on pa mode
does this radio have freq? if so you could have turned on causing
a miss alignment with antena.. check all the switches move into different positions and keep keying up, good antena connection?
swr?
tony
Dec 03, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
GPS Logo
493 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
