Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub 350 error code EA3226 when trying to scan to email
What does job status TX(NG)(EA3226) mean when trying to send to an email address?
  • amuromax Jan 08, 2009
    I had the same problem. Checked the SMTP settings and all are in order. Have no problems sending to another domain name. What else could be the problem besides the SMTP server? What does the error code EA3226 actually stands for?
  • Anonymous Mar 13, 2014
    What does job status TX(NG)(EAA000) mean when trying to send to an email address?
I changed the SMTP address from a name to an IP and that resolved it for me.
Posted on May 28, 2008
On C35 bizhun get error when scan to email SCAN TX FAILED JOB CANCELLED any help?
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
Oct 07, 2011 | Konica Minolta Konica Bizhub C353 Drum...
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
Nov 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error Code ED09C7 when scanning to the shared Network Folder
this means the computer name and or passwordare incorrect when creating the one touch key in the user name and password fields the user name and password must match exactly to the name and password on the pc
Oct 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Hi, I just took over a BizHub 350. Whenever I try to scan to a new email address, it doesn't go through and I get the error message "EA3226". Whenever I try to scan and email to an existing email...
The scan-to-email may have been set up originally to utilize the old email server, using the old domain as the conduit for sending the scans through your network.
You may have to load the driver onto the new email server, or the main network server itself (which would then allow you to scan to emails with any destination as it is using the networks connectivity to deliver the emails, not the email server).
Then you can set up as many new user accounts as you want.
Jun 25, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 250 error EA3226
Scanner operations
Error Code Cause Remedy
EAXXXX ImageReceiver was not started.
Start ImageReceiver.
The IP address2.gif of the recipient
is not specified correctly in the
dialog box that appears after
clicking “Receive Settings”,
then “Connection Filter”.
Click “Receive Settings”, then “Connection
Filter”, specify the correct IP
address, and then restart ImageReceiver.
ImageReceiver is not operating
correctly.
Restart the computer.
Re-install IP Scanner.
Check the TCP/IP2.gif settings on the computer.
The LAN cable is not connected.
Check that the LAN cable is correctly
connected.
The network settings2.gif on the
computer are not specified
correctly.
Check the TCP/IP settings on the computer.
The network load on the recipient’s
computer is too high.
Check that large e-mail messages are
not being received at the recipient’s
computer and that large files are not
being downloaded from the Web.
Too much data is being sent. If a high scanning resolution has been
specified, reduce the resolution or decrease
the number of pages scanned
at one time, and then scan the document
again.
Access is blocked by the setting
specified for the computer’s
firewall (Windows
firewall) for the Internet connection.
Change the setting specified for the
computer’s firewall (Windows firewall)
for the Internet connection according
to the instructions from your network
administrator.
Jun 24, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I have a Canon ir 3045 copier, when I try to send the scanned copy directly to a file, the file doesnot save to the destination network folder. When I looked at the scanner send logs i saw status as NG...
I have a Canon ir 3045 copier. I had sucessfully scanned two documents but the third scanned document (107 pages) was not emailed to me. When I click on press details, the job type reads #801. how do i retrieve the document?
Apr 24, 2009 | Office Equipment & Supplies
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
4,939 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
