MP3 and Digital Media Players
Problem for MP3 and Digital Media Players
Generic problem for all MP3 and Digital Media Players
Philips SA6185/02 8GB MP3 Player
By derekjb on May 13, 2008
I cannot get the philips 'convert to .wmv' program to work - when it tranfers to the player an error message says ' file format not supported use the philips file converter' although i already have ? this is the second player i have had from argos and i'm considering asking for my money back very soon as this is getting very frustrating.
Derek Brown.
Comments:
May 14, 2008
- Hello there and thanks for the response
The file types I am trying to convert are .avi.
I am using the Arcsoft converter that came on the cd with the player.
The model number of the player is 'SA6185/02 and shows in the arcsoft converter and on my computer as a 'SA61xx'
I have not tried .VOB files yet but will do soon.
Thanks
Derek Brown.
Clarification Request
Posted by avid_imps on May 14, 2008
What file type are you trying to convert to .WMV?
Also, are you using the Arcsoft video convertor? If not, it should be on the CD.
I think the Philips convertor was only for the SA31XX range.
If you are trying to convert .VOB DVD files, then it will not work directly from a bought DVD as it is copy protected.
Solution #1
posted on May 16, 2008
Not Rated)
avid_imps
Rank: Guru
Rating: 86%, 411 votes
It's unlikely to be a fault with the player.
I have just run the Arcsoft Convertor with a DivX encoded .AVI file and it processed correctly.
One possible cause of this problem is that you may not have DivX codecs installed on your PC.
To check this, try playing your .AVI file in Windows Media Player. If it doesn't play, then you will need to download the necessary codecs. Try www.divx.com
If it plays ok, then continue---->
I assume you are trying to convert and transfer directly to the SA6185.
In this case try converting the file before connecting the player and transferring:
Open Arcsoft Media Convertor
Drag the .AVI file into the program window
Click the "Select Player:" drop-down menu and select SA61xx manually.
The "Convert To" setting should default to Folder.
The default folder setting is My Documents/Arcsoft MediaConvertor/
Click "Convert" to start the process.
If this works, then when the process has finished, navigate to the converted file.
Connect the player to the PC, and drag & drop the .WMV file directly into the Video folder of the SA6185.
Disconnect the player when the display says "Ok to disconnect" and restart.
Go to the video option and your movie should be listed and ready to play back.
If the Convert process doesn't work then, the file is most definitely the cause of the problem. If so, post again with details of the file, and how it was created.
Was this helpful?
Yes
No
Popular Solutions for MP3 and Digital Media Players
Questions and Unsolved Problems for MP3 and Digital Media Players
Answer
Anyone recommend a good reasonably priced fm tuner for an ipod classic to turn into a radio and also... (More)
Answer
i want to buy a new dumbassss
Answer
my transcend t sonic 840 i por detecte ok bun start now and hanging problams
Answer
the unit does not power up and when connected to PC simply says recovery done but can not see as a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
