Question about Refrigerators
I have a bottom freezer kenmore refrigerator model 596.72253200 and its making a grinding sound coming from the freezer. i found out that when the light its off on the freezer its when the noise starts
  • 3,740 Answers
The noise your hearing is the evaporator fan. This is a sign of an automatig defrosting problem. Here is what you can do to prove that it is NOT an evaporator problem and most likely an automatic defrosting problem:
(MANUAL DEFROST)
1 Empty the freezer contents
2. Unplug the refrigerator
3. Place a fan blowing into the freezer section for about 2 hours.
(This will make a dripping water mess so be ready with the rags and the mop.)
4. After 2 hours wipe up the last bit of water mess.
5. Plug in the Freezer
6. Load freezer contents.
7. Listen for grinding noise.
My bet is the grinding noise is gone. However if you still hear it the evaporator fan motor has bad bearings in it.
The evaporator fan motor can be found here: (Item 18)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59672253200/0582/0161000/M0210209/00006?blt=06&prst=&shdMod=
If the noise is gone keep an eye on the unit after 2 days because if there is an automatic defrosting problem the noise WILL repeat.
The defrost control is item 13 this link: (Backordered)http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59672253200/0582/0161000/M0210209/00003?blt=06&prst=&shdMod=
Part number is: 12566102
I did find it in stock here:
http://www.pcappliancerepair.com/part-detail.php?affiliate_id=seabreeze&item=12566102&brand=WPL
There can be other reasons for not defrosting properly but the control is the most common failure.
Thanks for choosing FixYa.
Kelly
Posted on Sep 07, 2010
  • 62 Answers
SOURCE: Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Posted on Dec 06, 2008
dmftrucker
  • 1922 Answers
SOURCE: the refrigerator makes a popping sound
sounds like it's your self-defrost working normally as for things freezing,check temps in front and back of refrig and you may be able to raise temp to alleviate condition w/o food in frt end being too warm
Posted on Aug 23, 2009
Testimonial: "thank you As a matter-of-fact, I did try raising the temp and the popping did stop now I am going to buy a thermometer for the frig and freezer "
  • 1214 Answers
SOURCE: refrigerator was making a 'Thump
Unplugging for an hour won't allow it to defrost if that is what the problem is.
Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
Posted on Dec 18, 2009
heatman101
  • 43501 Answers
SOURCE: Model# 596-63822200 Bottom Freezer Refrigerator.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
heatman101
  • 43501 Answers
SOURCE: my kenmore bottom mount refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 12, 2011
MODEL MFD256OHES
Check the fan. It comes on at different times. It could be the source of the grinding sound.
Oct 06, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Kenmore refrigerator/freezer not cold! I have a Kenmore Coldspot model 57572791 refrigerator/freezer that suddenly stopped cooling/freezing. I took off the back & think it is the compressor @ the...
It is not likely, but since you had the lights on the same circuit it is possible that the breaker for that circuit may be tripped. Have you checked the breaker?
Jan 21, 2013 | Kenmore Refrigerators
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
My refrigerator side is making a grinding noise and today I noticed that it is warm. the freezer side is fine. I have a frigidaire frs26kf6e.
Hi and welcome to FixYa, I am Kelly.
That grinding noise is usually ice build up on the evaporator coils to the point that the evaporator fan blades strike the ice build up. i.e. Possibly an automatic defrosting problem.
Here is what you can do to find out.
1. Unplug the refrigerator
2. Remove the contents from the freezer section
3. Place a fan blowing into the freezer compartment for a little over 2 hours. THIS MAKES A WATER MESS so be prepared.
4. After the manual defrosting period with the fan then reload the freezer.
5. Plug the unit back in
6. After 4 hours recheck your freezer and fresh food section temps.
7. You should no longer hear the grinding sound
It is highly probable that the ice build up will repeat. If it does then for sure you have an automatic defrosting problem and will need to service the defrosting problem. At least you will know what caused the grinding noise.
If after all of this that grinding noise you heard is still present you will have to check the evaporator fan assembly for signs of bearing wear.
If the grinding noise is coming from the compressor... bad news the compressor rotor is dragging and that requires a compressor replacement.
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=frs26kf6e
(there are 2 missing digits from the model number)
Click on the model number of your exact model and the parts page will appear.
Thanks for using FixYa
Kelly
Apr 25, 2010 | Frigidaire FRS26KF6E Side by Side...
Kenmore bottom freezer, make clicking and gergging sounds, the unit is 8 yrs old
The gergging Is probably normal sounds of the compressor equalizing pressure when it cuts off. The clicking, could be the compressor starter relay possibly going bad making the noise when the compressor comes back on.
Jul 01, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Automatic Ice Maker making grinding noise and will not release ice
The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
May 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
