I have a carrier model pv 48nboo6. It worked fine intil I had it checked and they said the the evaporator coil and expansion valve needed to be changed out, which was done under warranty. This was done and it now sweats so much it has shut down at times when the pan fills up. They have put in new dry insulation and slowed the fan but it still sweats. What needs to be done they do not seam to know.
  • juelscarlson Sep 07, 2010
    Until they replaced the coil the AC worked fine for 4 years and we never had any sweating or water in the pan. Here is a picture of the problem.
    B4 they put in a new coil we had no water problem.
  • 43,501 Answers
Actually slowing down the fan will only make the condensation problem worse....they should speed the fan up, not slow it down...you need MORE air flow....also the expansion valve may need to be adjusted, but many A/C techs do not know how to do that...the valve needs to be adjustede so that the coil does not run quite so cold...
The best thing for you to do is to call Carrier directly and ask them if there is someone else they could send out to work on your system or if they could give direct factory assistance to the people you have....they should make everything right under warranty for you. I have found that calling the factory direct can get great results... they want to make sure that you are totally happy with your system!
Here is the link to Carrier
heatman101
Posted on Sep 08, 2010
I would install a dehumidifier unit and increase the fan speed to decrease the temperature drop across your A/C coil. Your excess condensation forms because the temp difference and humidity. The tempurture difference can also be overcome by adding more insulation
Posted on Sep 07, 2010
Where is the ac expansion valve located
The expansion valve is always located at the evaporator core inlet and outlet pipe.
Jul 27, 2015 | AC Cars & Trucks
Where do i find the expansion valve on a 3.5 ton trane air handler. Model no of the trane air handler is: 2TEC3F42C1000AA
The TXV (thermostatic expansion valve) is always at the end of the high pressure liquid line as it enters the evaporator. This is the small line. The outlet of the TXV will usually have 4, 6 or 8 smaller lines feeding proportional portions of the evaporator coil. You have to remove the cover of the evaporator to access it.
Some units do not use a TXV, so you may have a 'fixed restrictor' instead. It too is located where above described.
Apr 28, 2015 | Heating & Cooling
Where is the expansion valve for ac unit on a Saturn 2003 l series
expansion valves (TX valves-thermal expansion valve)are locate at the inlet tube at the top of the evaporator unit inside the car. The line from the condenser goes in one side and the evaporator coils on the other.. Not a DYI job.
Aug 10, 2014 | Cars & Trucks
Where is the exspanion valve on a carrier model 50dk507154
The expansion valve is always located at the evaporator. The inside cooling coil on most residential systems.
Jul 16, 2014 | Carrier Heating & Cooling
My ground source heat pump doesn't deliver the full power. (It is not a carrier model) I notice ice building up on the cold side of the refrigerant piping (heat exhanger inlet, liquid separator, until...
main reasons that cause ice on suction line
-low evap air flow
-low refrigerant
-low load
-liquid line restriction (possibly filter drier)
need a picture to further help
May 29, 2017 | Carrier New 5 Ton Ground Source Geothermal...
Ac problem
It normally is found in one of metallic pipes that go through the firewall to the evaporator coils. That pipe should also be the hot line coming from the condenser coil that is located next to the
radiator. It sometimes has crimp marks on that pipe to prevent the expansion valve from moving into the evaporator, Thanks Sea Breeze
Jun 13, 2013 | Heating & Cooling
Where is the orifice tube located on 88 buick park avenue
Inspect/Test/Replace To raise pressure, there must be a restriction in the air conditioning system. The restriction divides the system into the high side and the low side. The terms high side and low side refer to the high pressure and low pressure within the system.
The flow control can be either an orifice tube or a metering device called an expansion valve. A thermostatic expansion valve controls the amount of refrigerant that is allowed to flow to the evaporator. A temperature sensing bulb on the evaporator inlet controls the expansion valve.
  • A bad expansion valve will cause low readings on both the low and high side.
  • Failure of the sensing bulb is the most common problem.
  • Sometimes the valve can become plugged with debris.
  • If the sensing capillary tube is warm, there is high pressure that pushes on the diaphragm.
  • The sensing bulb checks the temperature of the outlet line of the evaporator.
  • If it is warm, it opens the valve.
  • Pressure on top of the diaphragm tries to push the valve open.
  • The operation of the expansion valve can be checked.
  • Some expansion valves can be cleaned, repaired or adjusted.
f73-15a.gif This system uses an expansion valve as it's flow control device. Some expansion valves are wrapped with insulation. When the sensing bulb is in the evaporator case, it does not need to be wrapped because it stays cold. When an expansion valve is packed in that type of system, it is only to silence the noise that the evaporator makes.
CAUTION
Only EPA-certified technicians can purchase R-12 refrigerant, since proper recovery and recycling techniques are required to prevent damaging the environment. Improper disposal of R-12 refrigerant can result in a fine.
Jun 06, 2012 | Buick Park Avenue Cars & Trucks
How do i replace my ac expansion valve?
{: ) You didn't mention your vehicle model. But anyway, the a/c expansion valve can be usually found at the engine compartment firewall, just a division away where it connects with the evaporator inside the dashboard. Just follow the trail of the two a/c pipes from the a/c compressor going towards the engine firewall, and there youl'll find a small rectangular block that serves as the junction point. That is the expansion valve.
The two pipes are mounted to the expansion by one or two bolts, depending on the model. Before you begin removing a/c components, make sure the surfaces especially the area of concern are cleaned, this is to prevent dirt or dust entering the a/c system. If possible, cover the pipes and openings. After removing the bolts, separate by pulling the two pipes aside. The expansion valve is mounted to the evaporator bracket, it's either a torx or an allen type bolts. You need to remove these bolts to separate the expansion valve from the evaporator bracket. Cover all openings of a/c lines to prevent contamination.
With the expansion valve removed, have time also to check the quality and color of the refrigerant oil. Check for possible contamination, flush the system if needed and reevaluate the condition of the compressor and condenser.
If everything seem to be fine, proceed with the new replacement of the expansion valve. It is also advisable not to reuse the old o-rings. Use new o-rings whenever possible.
Installation is just the reverse of the removal, so goodliuck.
I
Jul 23, 2011 | Chevrolet Corsica Cars & Trucks
Part no. expansion valve of Air cooled chiller
On a chiller with semi hermetic compressors can have different types of thermostatic expansion valves for metering. As far as a number, you will have to go to the evaporator to look at the tx valve and get the numbers. It may be a single ported, double ported, be externally equalized or not. You have to get the copper line sizes in and out also if you are planning to change the valve out. The valve will also have the type of freon the system uses if for some reason the data plate is worn off. That's the place to always find out is the expansion valve. If you need information other then what I have given you, contact me and I will help you.
Sincerely,
Shastalaker7
Mar 15, 2010 | Heating & Cooling
I have a carrier reefer trailer phonix ultra xl that at 25 degrees the low side drop in to a vacuum
Check for dirty evaporator coil, restricted liquid line filter, or defective expansion valve.
Aug 03, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
