Question about Dacor DMT2420 1200 Watts Microwave Oven
Runs but doesn't heat - Dacor DMT2420 1200 Watts Microwave Oven
  • 909 Answers
Look, i do not suggest you do it yourself as really, its lethal inside the covers, especially if you are not farmiliar with microwaves. What you need to replace to allow it to work 100% again, is to replace the magnatron and capacitor with the asspciated HVdiode.
Posted on Sep 07, 2010
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Mar 18, 2013 | Microwave Ovens
if it has a turntable does it move? Possible diode, inverter board (may have the diode on it or the Magnetron.
If an inexpensive unit it may be cheaper to replace than repair.
Nov 05, 2012 | Emerson Mw8999rd Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Microwave Ovens
Microwave runs but doesn't heat
HI>An oven is equipped with a heating filament that is called.Magnetron.Now if the motor is working but the unit is not heating .Then MAGNETRON is defective and must be replace.
Jul 22, 2011 | Maytag Microwave Ovens
Sometimes when I go to heat something in the microwave it doesn't heat but when I open the door and then close it it sometimes will work?
Sounds like the door switch is going bad this is the switch that "tells" the microwave the door is closed so that way it doesn't run with it open
Apr 26, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
The microwave timer runs but turnable plate doesn,t rotate and the heating elements doesn't comes on
you need a new microwave. There are no heating elements in mocrowaves just micro-waces. It only heats moisture it does not heat objects. It is to dangerous to replace the actual device that heats liquids.
Jan 24, 2010 | Emerson Microwave Ovens
Dacor DMT2420 1200 Watts Microwave Oven Logo
37 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
