Question about RCA 20F512T 20" TV
Power surge knocked out both TV (same Model) also lost cable modem. Removed cover don't smell burned. No sign of surge on board or wires. I have repaired computers for 20 years but never until now tried to trouble shoot a TV. Any help would be helpful.
  • Frank Miller
    Frank Miller May 14, 2008
    Have no power. do they have a power supply. I am also trying to find a manual for this model. Does not apear to be a fuse.
  • Frank Miller
    Frank Miller May 31, 2008
    Sorry I didn't close. I can replace the set cheaper than buying parts.
    Thank you
    Frank
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other).
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps...Thank you for using FIXYA!
IrishDruid
Posted on May 13, 2008
  • Swilin Sampson
    Swilin Sampson May 14, 2008
    Not able to find a manual yet. However, if its not the flyback, then you may want to consider replacing the power board..
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I replaced the power board with one from shop jimmy but still get no power/stand-by light at all. i can heard a very quiet rhythmic clicking from what sound like the power board.
The power surge may have affected components other than those on the power board. Check for burned components and signs of scorching or breakage.
Mar 22, 2016 | Samsung PN51E450A1FXZA 51-INCH 720P SLIM...
What is the first thing to check after a power surge caused by a close by lightning strike?
See if everything works. Stereos & TV's are usually the first to go. Items with digital devices go next analogs after that & grounded devices last. A whole house surge suppressor costs about 50 bucks and is just a few wires to connect & at the very least wall adapter surge suppressors should be connected to everything.
Aug 03, 2015 | Refrigerators
Power surge knocked out my video board. How do I order a replacement?
Barry,
if you include the make & model we may be able to help locate a board. Even better if you include board ID info including revision number. Suggestions include eBay or any of the reliable net based component vendors.
TV Boards Buying Guide
Jan 11, 2015 | Televison & Video
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
The tv smells like a burning wire
Can you describe where the odor is coming from. Is it coming out from the side panels on the tv set itself, or perhaps the plug, on end of the main power wire. Check around the electrical outlet. Make sure nothing else is plugged into the same outlet. It sounds as if some of the electrical components on the circuit board are burnt or burning out. Tv may have experienced a power surge, etc. Check also if the power plug is heating up. Be careful and smell around top side vents on tv. Be sure and unplug the set before leaving it unattended if you cannot locate the source of the "burning wire smell."
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Magnavox TV 25TS52 had power surge not working
You can call Magnavox customer support at this telephone number. 1-800-705-0000 Tell them the model number of your television and they will be able to help you. I hope this information helps you with your problem.
May 13, 2009 | Philips Magnavox 27MS343S 27" TV
Apex Digital GB43HD10
I was watching My Apex Digital GB43HD10 one night and i smelled smoke the TV went blank i lost all power, i called the repair man and he came and looked at it and replaced the thermosat and it solved the problem.
Oct 20, 2008 | Apex Digital GB4308 43" Rear Projection...
Panasonic WIDESCREEN 52" hdtv: power tries to come on and then there is a burning smell. The power button LED on the TV flashes several times. This starting happening after the TV was on and suddenly...
check of fluid leak from the tubes, check to see where the burning smell is comming from. could be anode, hv wire, splitter, surge caps in h-circuit, but it sounds like a high voltage transformer.
what is your model number of your tv?
Apr 10, 2008 | Televison & Video
Light Bulb Icon Flashing
Unplug it from power.Pull the side cover to check for burnt smell or burnt spots on your board modem or power supply. Unplug the power suppy from the board, unplug the hard drive . Then plug it all up again , put the cover back on it .Plug power cords back up and try it again.If you get no where after this the surge knocked out your power supply or hard drive or board. Always use a good surge protector on all computers and printer and copiers.
Aug 06, 2007 | Compaq Presario S6300NX PC Desktop
Power surge - how to repair??
Power surges on these can take out the main board (unnumbered), modem(3), and power supply(4), approx 150 each.
Jan 26, 2007 | Brother MFC 8820D All-In-One Laser Printer
RCA 20F512T 20" TV Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
