Question about Roland Spd-S Sampling Percussion Pad System
Roland SPD-S Flash card error
My SPD-S keeps telling me my flash card is unsupported. Im using a SanDisk 512mb and 1.0gb compact flash. Is this an improper card, or is there something wrong with my sampler??
  • 2 more comments
  • ashor99 Jul 24, 2008
    I have same promblem gays my memory card san disk 512mb i daonlownd sounds into memory when ever i put inspds it said card ematy any soultion i aprestietd gayes thanks.
  • Gjmayuri Aug 27, 2008
    I have 512 MB flash card and when inserted it shows unsupported. So, I checked in my computer and its working fine. So, I formatted in my computer (FAT) and then copied the data again in the card and tried again. But still it gives error - Unspported..
    Pl. suggest what to do ??
  • godspeedyou Sep 12, 2008
    I figured out the problem guys. The SPD-S is only compatible with certain brands and memory sizes of compact flash cards. I found a chart on Roland's website on which cards are compatible and which aren't.
    http://www.roland.com/products/en/_suppo...
    This solved my problem. I hope it solves all of yours.
  • spotdoc79
    spotdoc79 Jan 15, 2013
    I reformatted the cat with my computer. Set the allocation to 512, and format the card as exFAT. Hope this helps
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
Posted on Aug 26, 2008
For the "Unsupported" error message:
  • The SPD-S is only compatible with "TYPE 1" Compact Flash cards. Also, the maximum allowed size of the CF card is 512 mb. I tried 10 different CF card and they all worked fine although only 2 of them were actually listed as compatible cards but they were all Type 1 CF cards with 512 mb or less.
  • There is no way to avoid the type 1 restriction but you can cheat the SPD-S concerning the 512mb restriction. If you have a CF card with 1 gb or more and you don't mind to use only 512mb from it... you can use a disk partinionner tool (such as Partition Magic) to delete the current partition and create a new one of only 512mb (actually make 510 mb as the partition info takes some space).
For the "unformatted" error message:
  • Simply format your card as stated in page 67 of your manual.
Posted on Mar 23, 2009
I formatted the disk in the SPDS & loaded my Wav samples into the Roland SPD folder & in still get the unformatted message. what could be the problem ?
Posted on Oct 20, 2009
Compactflash card is showing damaged while inserting in spds
Posted on Mar 30, 2010
    Problem Solver:
  • 8 Answers
..and copy the WAVs to the ROLAND/SPD folder
Posted on Dec 31, 2008
  • BroeselHai Dec 31, 2008
    .. and ALWAYS "shut down" (=shift+card) before powering off!
    But hard, when suddenly everything goes black!
The card have to be formated in the Roland SPD and not in computer FAT
Posted on Sep 11, 2008
How to recover files from a crashed Compact Flash on my Roland SPD-S?
It's possible your CF card is full.
1. Connect the card to your computer as you have done. 2. Copy the files off it and save same them to a folder on your desktop.3. Right click only the Flash drive and navigate to "Properties" or "Get Info" if your a mac user.4. Take not of the file system it is currently using.5. Re-format the card with the same file system using your computer.6. Replace the card into your Roland SPD-S and Re-format using these steps: a. Select patch mode or wave mode. b. Press {SHIFT} and {SETUP} (CARD UTIL) c. Press the PAGE buttons to select "CARD FORMAT" then press {ENTER} d. A"[>] to format." indication appears. Press [>] e. A "format, sure?" indication is displayed. Press {ENTER} to start formatting.
7. Once formatted you can replace the card in your computers card reader and copy the files you backed up earlier onto it.8. Re-place the CF card in your Roland and it should work. If not then you may have a irreparable CF Card.
Oct 26, 2012 | Roland Spd-S Sampling Percussion Pad...
The display just showing(welcome to spds) nothing else. please help
I had the same problem after trying to do the update for the flash card (v1.20). I'm taking it back to the store now. I tell you what they tell me...
Aug 09, 2010 | Roland Spd-S Sampling Percussion Pad...
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
Compact Flash adapters
Hallo,
try the following program:
gogle for: GParted Live Disk
With this tool, you should be able to make TWO PARTITIONS on your 1GB CF-card (cheaper then 512MB) and create a partition with 510Mb (caution! NOT 512Mb!!).
Now you should be able to use the CF-card in your SPD-S.
Further advantage, you can store backups on the second partition, by copying them (on your PC) to the second partition.
Best regards,
Jan 04, 2009 | Roland Spd-S Sampling Percussion Pad...
KONICA MINOLTA DiMAGE 7i COMPATIBLE COMPACT FLASH CARD
go to www.memorysuppliers.com order the below item
1 SDCFB-1024-A10 - SanDisk 1GB / 1024MB Compact Flash card
Sep 22, 2008 | Konica Minolta DiMAGE 7i Digital Camera
File import
Try IMPORT instead of just trying to load them on your SPD-S.
The SPD-S uses some kind of its own file-format.
Regards
May 18, 2008 | Roland Spd-S Sampling Percussion Pad...
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
CF Excessive Power
Nikons and Fujis keep the CF slot powered, and "poll" it every now and then to see if a card has been removed or inserted. So yes, a camera may drain batteries much faster with a CF card than it does with an XD. But if it really does do this, then someone at Fuji deserves to be on the street, looking for a new job. Polling a card every few seconds does not have to be a traumatic experience to the camera. A Nikon can sleep for months, and not show appreciable battery drain. After what I've seen in the horribly slow CF write times of the S3, and the large artificial difference in write times between CF and xD on that camera, I'd say someone (or several "someones") at Fuji is doing everything in their power to make CF look bad and steer people into xD.
Sep 12, 2005 | Fuji FinePix S7000 Digital Camera
Roland Spd-S Sampling Percussion Pad System Logo
6,162 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
