Question about Symbol LS3578-ER Rugged Barcode Scanner
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
    Scholar:
  • 117 Answers
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Posted on Sep 08, 2010
  • Ncosio May 12, 2011
    After I did this; by accident I disconnected the power cord of the base and the scanner started working
    i connected the power cord and the scanner stoped working
    I disconnect the power cord and the scanner sends a beep and the scanner reads the bar code
    regard
    Problem Solver:
  • 18 Answers
Any differences between the barcode scanner I am testing and the one you mentioned above?
World Leading NET SDK for Barcode Scanning pqScan com
Posted on Dec 21, 2015
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf&sliceId=&dialogID=219596399&stateId=1%200%20219598121
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
Feb 26, 2011 | Symbol LS2208 Handheld
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
When I scan a barcode with the Symbol LS 4278 scanner it duplicates the barcode. How can I fix this?
There was probably some kind of ADF Rule applyed, please scan the barcode Set All Defaults and Erase All Rules from ADF Chapter in the manual for LS4278 aailable here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=190394003&stateId=1%200%20190388491
May 03, 2010 | Symbol LS 4278 Barcode Scanner
3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Oct 05, 2009 | Symbol LS 4278 Barcode Scanner
Manual carriage return necessary after scanning barcode
With the Symbol scanners, they usually come with a sheet at least of scan codes to configure the scanner. One of those bar codes will have the option of not needing to manually hit the carriage return. What model scanners are they? You can probably find the codes from Symbol.
Sep 17, 2009 | Symbol LS 2208 Barcode Scanner
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
Jul 12, 2009 | Symbol M2004 Barcode Scanner
4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Apr 14, 2009 | Symbol LS2208-7AZK0100S Handheld
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Symbol Spark LS 1004 Problem
What do you mean? you can only scan not more than 3 times? If that so,you need to change the setting of your scanner there was a limit numbers to scan. You can check by using the manual of that scanner.
Hope you like my solution please rate me SOLVE.
Best regards,
Philip
Oct 18, 2007 | Symbol Spark LS 1004
Symbol LS3578-ER Rugged Barcode Scanner Logo
6,425 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
