Question about John Deere Garden
My lx279 won't start. It just 'clicks' but starter doesn't engage.
2 Suggested Answers
BAMOUT
  • 2478 Answers
SOURCE: Mower won't turn over, I hear a click sound
Your owner's manual has a wiring schematic. Check the fuse on back of motor or behind it. 30 amp.
Posted on Jan 22, 2012
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
The starter motor will not engage
Hi, Paul the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter spins but doesn turn the engine
Starter spins but won catch
http://www.apriliaforum.com/forums/showthread.php?189764-starter-spins-but-doesnt-engage
Inside look of starter spinning but not engaging
May 15, 2016 | Motorcycles
My 2006 r6 starter relay clicks like a dead battery and my bike wont start and my starter just spins my motor wont turn
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r1-forum.com/forums
Won start just clicks but can push start Jumping relay doesn start it
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Sep 01, 2013 | Yamaha YZF-R6 Motorcycles
My 2000 Pontiac Montana won't start. I hear a clicking noise from the back but the starter doesn't engage
have somebody hit the starter with a hammer while somebody turns the key on the start position as he holds the key keep hitting the starter not at the solenoid at the round part if it tries to start then you have a defective starter now if you have a alarm system you are going to have tutoo isolate the starter to do a different test.
Apr 16, 2013 | Cars & Trucks
Starter won't engage on 17.5 koehler command
Try replacing the solenoid. If that doesn't do it, replace the starter.
May 05, 2012 | John Deere Garden
Starter works fine but won't crank engine. the pick up has to be given a push first before it starts
If the starter is spinning when you try to start but doesn't spin the engine over then you most likely have teeth missing off the flywheel ring gear. The facts that you say you have to push it and then it starts means the flywheel position changes and the starter has good teeth on the flywheel to engage. To confirm this next time the engine won't crank over remove the starter and look inside at the flywheel for missing flywheel teeth.
Mar 13, 2012 | Ford Cars & Trucks
Engine wont turn over on my gv 2006
The 1st thing i need to do is clarify what you mean by "won't trun over" do you mean the starter motor spins the engine and it will not fire up or that the starter doesn't trun the engine over? If the starter doesn't turn the engine over do you hear a clicking coming from the starter solenoid when this happens? If so replace the starter solenoid the heavy electrical contacts are burned.
Dec 28, 2011 | 2006 Suzuki Grand Vitara
I have a 1988 911 3.2 Carrera that sometimes doesn't start. Won't even turn over. Usually after I have driven somewhere and it's sit for an hour or more. There is a very, very, slight click...
I would start with the solenoid as usually when they go bad all you hear is a click when you go to engage the starter and then the starter doesn't rollover the engine.
Apr 24, 2017 | Cars & Trucks
2004 ion won't start. Lights work. When I turn key don't get series of clicks, get one snap.
That symptom usually means the solenoid on the starter is bad and no longer is completing the circuit to engage the starter. A new starter will likely solve that issue. A series of rapid clicks would indicate a week battery. You can try repeatedly turning the key to the start position rapidly, sometimes the starter wil start working. You can also try tapping the starter while somebody holds the key in the start position, if the starter engages place it.
Jul 16, 2011 | Saturn Ion Cars & Trucks
Garden Logo
219 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
