Question about Bosch Nexxt WTMC 3300 Electric Dryer
When I press Start the dryer does not tumble - Bosch Nexxt WTMC 3300 Electric Dryer
  • Bosch Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
5 Suggested Answers
  • 67 Answers
SOURCE: dryer does not tumble, but heats up
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
todd0708
  • 247 Answers
SOURCE: hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Posted on Sep 22, 2009
miket756
  • 2702 Answers
SOURCE: dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Posted on Nov 16, 2009
  • 1891 Answers
SOURCE: My Kenmore dryer 78942892 won't tumble when I
sounds like the motor . remove drum and try to turn shaft . i think you will fint it won't . replace motor .. m m
Posted on Dec 24, 2009
Lg tromm DLE5977 won't start the tumble
Sounds like loose belt. If the drum spins by hand, it's almost guaranteed to be a bad belt.
Nov 27, 2013 | LG DLE5932W Electric Dryer
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
My Kenmore dryer 78942892 won't tumble when I press the start button. It begins makes a noise but doesn't tumble, then it just turns off.
Dec 24, 2009 | Kenmore 63942 Dryer
Dryer wont tumble
Nov 16, 2009 | Dryers
Hotpoint ctd40 t dryer. wont start just ticking.
Sep 22, 2009 | Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
My hotpoint vtd20 tumble dryer will not start. I was using it then when I put a second load in and pressed start - nothing happened. The power light is on but no tumbling!
If you can hear the motor running but no tumble action then belt has come off.
Make sure the door is shut properly..
If it gets hot at the back, then you are difinately getting power to everything.
If you can hear a slight buzzing noise, then the motor is failing to start, probably due to a faulty start capacitor.
Dec 08, 2008 | Dryers
Dryer will not tumble
HI your right on the money , it is the belt. replace thanks.
Oct 11, 2008 | Maytag PYE4557A Dryer
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
109 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
