Question about GE Dishwashers
I have a GE Profile PDW8280J03ss ser#DH842601B and it won't drain all the way??? What can I do before calling a repairman?
  • GE Master
  • 3,740 Answers
Usually this is due to a partially blocked drain. Most of the time the problem is either at the sink / garbage disposal connection or the Air-Gap is blocked near your sink. The air gap sticks up above the sink about 2.5 inches. You lift off the cover, unscrew the inner plastic nut NOTING installed position of the upper cap and lift off the cap. There may be food particulate in there. Clean it out and put it back together. If you foind nothing there then remove the hose from your under sink connection and clean the hole out that the hose connects to.
If you do all of the above and the problem persists just repsond here and we can continue troubleshooting.
Thanks for choosing FixYa.
Kelly
Posted on Sep 07, 2010
  • Kelly
    Kelly Jan 09, 2011
    Hi again, I had asked that you clean the air gap and the sink connection portions of the drain and then hopefully you would comment so we could continue troubleshooting, The fact that the post was rated tell me that you either did not clean the drain ports or you just did not accept the fact that a partially clogged drain does in fact cause water to be left in the dishwasher after a frain cycle. Since you made not a single work comment and obviously are not interested in a DIY repair as I said there is more that can be done and all you had to do was respond it seems my efforts to help you have gone to waste. I have been doing this for over 40 years and passed you sound advice expecting a typed reponse from you if cleaning the air-gap and drain ports did not correct your drain problem. Here is a just a little of my history: http://blog.fixya.com/index.php/2010/05/...
    We had a family owned buisness and I worked at 2 other in home Appliance repair shops over the years.
    Due to a 2 TU rating and no response it appears you have no interest in getting the symptoms corrected. If you really want to correct the problem respond here AFTER you make sure the Air-Gap and sink drain connevtions have ben opened and cleaned and we can start checking inside the dishwasher to determine the cause of your poor draining problem. Unless you respond I will make no further comments.
    Kelly
  • Kelly
    Kelly Jan 09, 2011
    Corrected Post. Spelling was awful!
    Hi again, I had asked that you clean the air gap and the sink connection portions of the drain and then hopefully you would comment so we could continue troubleshooting, The fact that the post was rated tell me that you either did not clean the drain ports or you just did not accept the fact that a partially clogged drain does in fact cause water to be left in the dishwasher after a drain cycle. Since you made not a single work comment and obviously are not interested in a DIY repair as I said there is more that can be done and all you had to do was respond it seems my efforts to help you have gone to waste. I have been doing this for over 40 years and passed you sound advice expecting a typed response from you if cleaning the air-gap and drain ports did not correct your drain problem. Here is a just a little of my history:http://blog.fixya.com/index.php/2010/05/... We had a family owned business and I worked at 2 other in home Appliance repair shops over the years. Due to a 2 TU rating and no response it appears you have no interest in getting the symptoms corrected. If you really want to correct the problem respond here AFTER you make sure the Air-Gap and sink drain connections have ben opened and cleaned and we can start checking inside the dishwasher to determine the cause of your poor draining problem. Unless you respond I will make no further comments. Kelly
    Lets just as an example proceed as if I were called to you home to repair your dishwasher.
    Before I did any of the below steps I would disconnect the Air-Gap and Sink connections and clean them thoroughly.
    The next step would have been to unmount the pump and check item 328 and 329 of this link for obstructions:
    http://www.appliancepartspros.com/partse... Additionally you would check the pump inlet for ostructions and the drain pump impeller for damage.
    That would be followed by removing the drain hose item 463 and checking the pump port for obstructions and looking at the outer portion of the impeller blades for damage.
    After that the turbidity sensor Item 321 would be removed and the sump would be checked for debris using a flashlight. Usually by this time the drainage problem would have been determined but if not the sump assembly Item 505 would have to be removed and cleaned along with verification that the sump plate was free of debris.
    Kelly
Our PDW8280J03SS caught fire and brunt out at the control panel. Is this a problem with this model. I see other models have been recalled for this exact same problem but cannot find anything for the...
You should tell the manufacturer as it is obviously a generic problem if there have been recalls. Ask them what they are prepared to do for you. You must put it in writing, no use using the phone.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Our GE refrigerator which is less than 9 months old is not producing ice and/or water
It is under warranty so you need to call a qualified GE repairman in your area.
Jan 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge profile washer has a d5 code that is displayed machine
CHECK THE TIMER. I DON'T KNOW IF THAT IS WHAT IT IS, BUT IF IT IS YOUR TIMER, YOU NEED TO CALL A REPAIRMAN AND SEE IF HE CAN FIX IT FOR YA. HOW OLD IS YOUR WASHER?
RODNEY
Apr 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Electricity went out last night. when i get up this morning, it is making a high pitch squeeling noise and now none of the buttons work????? its a ge profile dishwasher
The electricity probably "surged" when the power came back on. It sounds lke the conrol board may have "fried". Call the repairman and get an estimate.
Mar 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile Harmony not draining wash load
HOW OLD IS YOUR WASHER? IT SHOULDN'T COST THAT MUCH TO REPAIR IF YOU CAN'T FIX IT. IT SOUND LIKE YOU MIGHT HAVE A PROBLEM WITH THE BELT OR MOTOR COUPLING. I DO NOT WANT TO TELL YA WRONG. I JUST HOPE YOU CAN GET YOUR PROBLEM FIXED. TRY TO CALL A REPAIRMAN SOON. GOOD LUCK.
RODNEY
Mar 27, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Water not draining and glasses look filmy
Call the repairman unless you are comfortable replacing the pump. It sounds like the pump is getting old and weak. The other possibility is that the pump impellers are caked with yuck. Depending on the manufacturer, they are replaceable, if they aren't cleanable.
Mar 17, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwashing powder/liqud will not dissolve
Is your dishwasher filling and draining? The detergent should mix, completely with the wash water and there should be no residue of just detergent. Make certain that the machine is filling and draining properly, otherwise, call the repairman.
Mar 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
I have a GE PDW 8200 Dishwasher and there is standing water in the bottom of the tube. Why is there standing water after a complete cycle?
If it is older, the pump may not be draining the machine completely. The impellers, which is what acually moves the water could be clogged with yuck and could be cleaned if you can take the machine apart. If you call the repairman, he will likely replace the pump and motor.
Feb 24, 2009 | GE 24 in. Profile PDW7800 Built-in...
The panel on my ge profile ss dishwasher is not working...
At first thought, it sounds like the control board has gone bad. Make certain it is properly plugged in. If no luck there, call the repairman.
Feb 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
234 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
