Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon Pixma MP130 Error message:- cartridge jammed service error 5100 How do I rectify this problem?
  • menchy11 Jul 16, 2008
    canon pixma mp130 error message:- catridge jammed
  • gintautask Sep 28, 2008
    Canon Pixma MP130
    Error message:- cartridge problem then i tryed to print documents
Try pressing the "copy" button and then the black "start" button. I did this a couple of times and the printer started working again.
Other people have had success when they open the lid, pull down the gate (to expose the cartridges) and then push in the little button on the left (to fool the printer into thinking the lid is closed). With that button pushed in, try pressing the "copy" button and then the black "start" button. The printer will make some working noises. When you close everything up again, it should work.
Posted on Oct 25, 2008
I HAVE THE SAME PROBLEM- CARTRIDGE JAMMED-. :o( I HATE PIXMA MP130, cant seen to make it work, last resort: throw it against the wall! GGRRRR! if you find a solution please post.
Posted on Aug 06, 2008
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I am getting an error 5100 message. On the printer it says cartridge jammed thanks
Hello and WelcomeError 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If it is HELPFUL, Please Rate it as Four Thumbs THANKS
Mar 08, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hi, I am trying to print a report and I get a service error 5100. I have cancelled print job and pressed ok, done this a number of times, still get the error, please help
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day. .top3Module { BACKGROUND-IMAGE: url(/images/Reviews/Top_3_BG_Asset.jpg); WIDTH: 310px; BACKGROUND-REPEAT: no-repeat; MARGIN-BOTTOM: 15px; HEIGHT: 361px } #RNR_rpt_div A { COLOR: #0033cc; FONT-SIZE: 12px !important; TEXT-DECORATION: none } #RNR_rpt_div IMG { VERTICAL-ALIGN: middle } .toptitleBest { MARGIN-TOP: 19px; FLOAT: left; COLOR: #4f81bd; MARGIN-LEFT: 19px; FONT-SIZE: 18px; FONT-WEIGHT: bold } .wrapperDiv:hover { CURSOR: hand } .wrapperDiv { FLOAT: left }
Dec 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP130 error 5100
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100 Yes see lots of this errors
Solution 1:
Solution 2:
Mar 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon pixma mp130 5100 service error
Hi You can Try 2 things.
Hope you try it may work
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Solution 2:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Jul 31, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
338 people viewed this question
old marine
old marine
