Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
I am using acer aspire 5920, and the dvd rw is not working properly. 1. the tray is not coming out by simply pressing eject button. 2. if i took out the tray using a sharp pin in the hole provided, the tray comes out but then the optical drive do not recognise the cd/dvd please help
    Guru:
  • Acer Master
  • 468 Answers
It happens when the Software that is not Windows Vista capable (such as printer software, CD burning software, and games) may have modified the registry to cause the optical drive to not function.
Please follow the steps below:
1.From the Windows Vista default Start menu, point to All Programs, Accessories, and then clickRun.
2.In the Run dialog box, type: Regedit. Click OK.
3.In the User Account Control dialog box, click Continue.
4.In the Registry Editor window, locate and then click to select the following registry subkey:HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5.From the File menu, click Export.
6.In the File name dialog box, type: Savedkey, and then click Save.
7.Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, clickDelete. When you are prompted to confirm the deletion, click Yes.
8.Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, clickDelete. When you are prompted to confirm the deletion, click Yes.
9.In the Registry Editor window, from the File menu, click Exit.
10.Shut down Windows® and restart the computer.
Thanks and regards,
Anil.B.R
Posted on Sep 07, 2010
Dvd has slipped right in. No sign of it. How do I remove disc tray to retrieve it?
1.Prepare a small needle
2.Locate a tiny hole next to eject button ( on the right next to eject button )
3.push the needle to the tiny hole.( the drives tray will eject softly )
akee_akee@live.com
Aug 16, 2011 | Acer Aspire 5500 5570-2609 Laptop
HOW DO I REMOVE DVD ROM FROM ACER ASPIRE 5315
im assuming the "eject" button is not respomding, no worries REAL easy fix, if you have a paper clip, if not find something the same diameter, if so, unfold paper clip and there should be a small hole on the door next to the "eject" button, insert end of paper clip, retrieve dvd.. :)
Apr 14, 2011 | Acer Aspire 5315 Notebook
Dvd rom, acer aspire 4720z not working.
probably it is something mechanical with it if it not rejecting it but from that pin hole ...get it out by removing the screw in the back on its level...one or 2 depend on the model ..after this just open the tray and jiggle i gently and it come out from the plug ..and look to see if it has all stuff in place ..and if it can not be repaired just replace it ..
Also you can try a bootable disk to see if it is not a driver issue from a bug ..and try to boot from it into windows or so
May 13, 2010 | Acer Aspire 5100 Notebook
How to open dvd or cd drive acer computer
1. There should be a button in the middle of the CDROM tray, click on it and it will eject the CDROM Tray.
2. Open My Computer> Right click on CD/DVDROM icon & click eject.
Mar 12, 2010 | Acer Aspire 5610-4648 Notebook
How to insert dvd in acer 5538
Since there is no external drive bay button on the Acer 5538, you either insert a paperclip or similar object into the pinhole on the optical drive door until it opens or...open the 'Start' menu, click 'Computer' (1/2-way down under the user picture), highlight the 'DVD RW drive' and mouse click 'eject' under the top-screen toolbar. I hope this helps.
Jan 17, 2010 | Computers & Internet
Laptop will not switch off untill press switch button of laptop
you have a corrupted software try to format and reinstall it again, most corrupted system comes from improper shut down sometimes during installation your CD or DVD rom is defective although it is reading and seams working fine try to install your system using other rom drive
Sep 18, 2009 | Acer Aspire 5920-6727 Notebook
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
DVD Door Won't Open
I have this problem with my DVD rom too. I don't know if we have the same ones or not. I took mine apart to try and diagnose the problem, and it turns out that there was this thing inside that wasn't dropping down all the way to allow the tray to slide out, it was staying locked in place.
I was unable to find a cure for this.
However, I found that when I press the button to open the DVD rom, when it fails to open, I give the top of mt computer a slap, and it un-locks the mechanism and the DVD tray slides out properly.
I hope this helps.
Jan 04, 2009 | Acer (91.48R37.002) CD-RW/DVD-ROM (Combo)...
Tray will not eject on LTR 16102B CD-RW
Most likely due to a worn belt. You can use a paper clip in the manual eject hole while pressing the button repeatedly to get it open. The belt or the drive will need to be replaced.
Jul 07, 2008 | Lite On LTR 16102B CD-RW Burner
Failure opening the tray
do 1 thing,take a pin and insert it in the small hole below the tray
and then press the eject button
Jun 04, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
390 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
