Question about JVC AV-48WP30 48" Rear Projection Television
MY JVC REAR PROJECTION TV HAS VERTICAL LINES AND THE V CHIP LOCK IS ON AND I DONT HAVE CODE, IS THERE A WAY TO RESETBYPASS IT
Slinteriors
  • 8617 Answers
SOURCE: vertical green lines
Call where you bought the TV. This is not normal for an LCD TV. They should exchange it only being a week old.
Posted on Jan 20, 2008
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
SOURCE: cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Posted on May 11, 2008
  • 108 Answers
SOURCE: I have a 50 inch
Replace the optical block assembly
Posted on Jan 08, 2009
SOURCE: Older projection TV reduce picture quality
Most likely its serveral suface mount capacitors, part of the Comb Filter. Very fixable...
Posted on Mar 16, 2009
Red lines still on jvc 48" rear projection tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 14, 2014 | JVC LT-42X579 42 in. LCD TV
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
I CANT ADJUST THE RED VERTICAL LINES ON MY JVC REAR PROJECTION TV. i HAVE DONE CONVERGENCE AND MANUALLY ADJUSTED THE RED LINES HORIZONTALLY, BUT NO LUCK WHAT CONTROLS TO USE VERTICALLY
If it will not adjust up or down or left and right the convergence chips need to be replaced.
See attached photos of board that is in your set:
This can be a do it yourself repair and the parts do not cost a fortune.
Can I help?
SD TECH
Oct 16, 2011 | JVC AV-48WP30 48" Rear Projection...
My JVC HDTV station is locked on Channel 3, How do I unlock it from this station
Hello
To unlock the panel lock of your JVC tv do the following.
Turn on the JVC television and press the "Menu" key on the remote control.
Use the Up and Down or Channel buttton to toggle through thre menu selections until V-chip appears.
Stop on V-chip and press the right arrow button to display a padlock icon
Enter the four-digit code by pressing the numbers on the keypad. If a code has not been entered, the default code is 0000 (four zeros).
Press the right-arrow key to unlock the channels
Unplug the JVC television for at least 15 minutes to reset the code to 0000 if a previously set code has been lost or forgotten
OK
Mar 22, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Vertical lines appear on the screen.
It appears like there is a bad capacitor in the horizontal circuit. Try to put a fan near the ventilation trap, just for a test.
the part cost almost nothing but having someone to your house is expensive.
Your decision.
Jul 01, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
JVC 56
thrse television are ila? which i a projection lamp type tv. burn in is internal to optics and will rigure replacment of light engine
Jan 29, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Red is all over the place but have a claer picture.
Its a convergence problem. I had the same problem you have to replace an av 110 chip in the tv.Mine was under warrenty so I had it fixed for free. Dont know what it costs otherwise.
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
162 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
