HP printer 4250. am getting a error message 81.0180.......EIO 1 any help here?
    President:
  • 1,070 Answers
Welcome to FixYa
Dear User
Do Following Steps Carefully..
  • Turn off Printer Power & Turn it On
  • Unplug Printer power-Re seat EIO accessory in Slot and Switch on Printer
  • power Off printer then Remove EIO Accessory from slot then Install in a other Eio slot and Turn it On..
Still Problem Replace the EIO accessory in slot....
Hope you got it...Thanks for Connecting FixYa..
Posted on Sep 07, 2010
3 Suggested Answers
  • 3 Answers
SOURCE: HP Colour LaserJet 4600dn printer problem
Try to remove the jet direct card into another slot. If that does not work you need to purchase a new jet direct card.
Posted on Oct 31, 2007
KingDWS
  • 1606 Answers
SOURCE: ''HP Laserjet 4600, Error code 81 0180 E10 1 Error''
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Posted on Jul 09, 2009
What does the error message EI0 1 Mean on the 8150dn printer?
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Mar 10, 2015 | HP LaserJet 8150 Printer
I am getting an error of: 49.4Co2 on my HP color laserJet 5550hdn. Have tied turning it off; unplugging butno luck. the error message continues to appear
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application.
If the job prints, go back to the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all
cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer.
Aug 29, 2011 | HP Color LaserJet 5550hdn Printer
49 ff95 service error for hp 5200n LJ
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other
causes include poor-quality parallel cable, poor connections, or home-grown programs.
1. Turn the printer off and then on.
2. Press Stop to clear all print jobs from the printer memory.
3. Turn the printer off and then on.
4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message only appears when using certain software programs, contact the software program vendor for assistance.
5. If the message persists with different
software programs and print jobs, disconnect all of the cables and turn the printer off.
6. If the error persists, perform a firmware upgrade.
7. Remove all DIMMs, EIO devices, and CompactFlash solutions.
8. Remove all EIO devices.
9. Turn the printer on.
10. If the error does not persist, reinstall the DIMMs, EIO devices, and CompactFlash one at a time.
NOTE You must turn the printer off and then on when reinstalling each component.
11. Replace the DIMM, EIO device, or CompactFlash if necessary.
12. Reconnect all of the cables.
Jul 16, 2011 | HP LaserJet 2420dn Printer
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
49, 4c02 error in hp 4250
This is what the result for that error code is:-
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter.
Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Feb 08, 2011 | HP LaserJet 4250dtn Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Hp Laserjet 2300n printer with error 81.0180 EIO 1 ERROR
You have a problem with the device plugged into EIO slot 1. Most likely it's a JetDirect card. Turn power off and reseat the card. Power up, if problem is still there put the card in the other EIO slot. There should be 2 EIO slots. If it still fails you will have to replace the JetDirect
Oct 07, 2010 | HP LaserJet 2300N Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
`permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
May 27, 2009 | HP LaserJet 4250n Printer
LaserJet 2420dn Error
The error means -
occurred.
Recommended action
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
4. Remove all of the
5. Turn the printer on.
6. If the error message
disappears, reinstall
individually, making sure to
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
10. Replace the formatter
Jun 03, 2008 | HP LaserJet 2420dn Printer
2,225 people viewed this question
k24674
