Question about Maytag Dryers
MY DRYER WILL NOT COME ON THE KNOB CLICKS AND BEEPS BUT THAT IS ALL NO LIGHT
  • Kelly
    Kelly Sep 07, 2010
    We need your model number of your Maytag dryer please to help you. Because you did not include it on your initial post any expert responding is going to ask the same question. Be prepaired for lots of "What is your model number?" questions from those experts.
    Kelly
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Recalibrate the WTW4950XW0Q
Instructions should have come with control take the knob and spin left about 5 clicks to clear rotate knob 3 clicks clockwise 1 click counterclockwise 1 click clock all within 8 seconds all lights should light up rotate knob till rinse light lit press start
Jan 06, 2015 | Washing Machines
Kenmore Gas Dryer he3 110.94821300 - lint light comes on and when you try to start dryer and dryer will not work. door switch clicks when pressed by hand so i do not think that is the issue.
Hi, at the top of the blower housing there is a white part with 2 wires. it is the thermal fuse. if you have a meter use the continuity scale and disconnect one wire from it and measure across it. if it beeps then is ok,if it not replace it. this is the most likely failure on what you describe.
Feb 15, 2011 | Kenmore Dryers
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
After choosing dryer cycle by turning the selection knob, I try to start cycle by pressing big Start button. It beeps several fast beeps. Also the drum light just stopped coming on.
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 20, 2010 | Whirlpool GEW9250 Electric Dryer
Eurotech dryer. ON light flashes on and off, beeps once, and still flashes then nothing happens, dryer won't start. Help?
The problem is that you stopped a cycle before the program knob reached the "STOP" (12 o'clock on the knob). All you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the ON/OFF light will stop blinking. Turn the program knob to the cycle you want and- viola! you're good to go!
May 20, 2010 | EuroTech EDC158 Electric Dryer
Dryer not working
How do you know the belt is on? Did you take the unit apart? Maybe a connection to the control knob came off. Otherwise:
1) Check the breaker to see if it has been tripped
2) Dryer plugged in
3) dryer door securly closed
4) if your unit is a single knob with various dryer settings, try a different setting (delicate, permanent press, etc)
5) if your unit has a start button, set the knob to the desired setting first, then press start.
Jun 09, 2009 | Whirlpool Dryers
Dryer not starting
Luckily, these units usually have a wiring schematic on the back, if not google it. The first thing on a washer or dryer to fail is the door switch. It's easy to replace or bypass. After that the start button itself may be bad. Follow the circuit, be careful. Use a continuity meter that beeps to check stuff. You mention a light. That means the door switch controls the light and the dryer, there will be a normally open leg and a normally closed leg. Good luck.
Nov 18, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
37 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
