Question about Price Pfister Treviso Wide Lavatory Faucet T49-DK00
How do I remove handle of lavatory faucet to replace cartridge? The faucet is dripping and making a noise
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
There should be a small hole under each lever handle. Inside the hole is a handle setscrew. Use a 2.5mm hex wrench to loosen, not remove, the setscrew. turn the screw counter clockwise to loosen, and then the handel should just pull straight up and off the faucet. Here is a parts breakdown for the PRICE PFISTER Treviso Wide Lavatory Faucet T49-DK00.
Posted on Sep 08, 2010
Ll800-BN faucet drips after water is turned off need to know how to make adjustment
More than likely, the cartridge will need to be replaced. I am not familiar with this particular faucet. However, most faucets are very similar in the breakdown procedures.
Be sure, first, to make sure water is turned off at the shut-off valves under the sink. Next, you should find a set screw on the handle; this is usually removed with an allen wrench. The screw is typically located on the handle of the faucet; often times, the set screw is covered by a small plug that is either red and blue, or will match the finish of the faucet.
Once you remove the handle, you may find another screw-typically it is a #2 Phillips screw, or a nut that loosens to gain access to the cartridge. Once you remove that assembly, the cartridge will need to be removed. Also, there may be a slide clip holding the cartridge; if it has that clip, you will find it just under the stem of the cartridge and it is usually found closest to the wall side of the faucet. Manufactures make cartridge removal tools, as sometimes the cartridge can be difficult to pull out. However, more often than not, I use a pair of channel locks. If you choose that method, just be sure you do not scratch the finish on your faucet. Keep in mind, it may take some force to remove the cartridge.
If you order a new cartridge for your faucet beforehand, the new cartridge will come with replacement instructions.
This is a very simple procedure for a handy homeowner to tackle. If you call the services of a plumber, I expect your cost to be anywhere from $75-$125. Again, just be certain that water is turned off first.
Apr 16, 2014 | Giagni LL800 Andante Open Trough 1-Handle...
Double faucets cartridge replaced still drips
My best advice
is to believe everything you just experienced...
(Perhaps an UNSEEN flaw in the "MONOBLOCK")
Buy the replacement faucet... shop around:
I spotted it on eBay... (number not close...)
((but still reasonably priced)).
AMAZON
American Standard 1480 101 002 Seva Single Control Lavatory Faucet with...
Also went to eFaucets (but their site was stunned
(normally GOOD resource... ))
http://efaucets.com/
eBay (concierge... buyer protected... FREE ship'n)
American Standard 1480 150 002 Seva Monoblock Single Lever Handle Lavatory...
Save the old one (parts)and DIAGNOSE
it in your SPARE TIME...
Hope this helps
Carnac the Magnificent
Oct 19, 2017 | American Standard - Lavatory Faucet -...
Faucet is dropping it is a one handle
First turn water supply to faucet off and remove handle. Remove cartridge from inside faucet and replace with new cartridge. Make sure you tighten cartridge to snug. Don't over tighten.
Aug 10, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Peerless faucet P99196 dripping; tried everything. Only made it drip more. How to fix?
If you have replaced boots and springs and or cartridges. Did you replace with after market parts or OEM. If after market parts were used use OEM. Hope this helps.
Apr 11, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
How to fix a dripping faucet?American Standard single lever handle.
Hello. These faucets use a replaceable cartridge valve and when they drip they're ready for replacement. Remove the handle by loosening a small screw ,usually with an allen wrench, and maybe another nut under it.The cartridge should pull out but mat be stubborn. Take the valve with you when you go shopping there are many variations.
builderdale
Jan 22, 2010 | American Standard - Lavatory Faucet -...
How do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
I have a two-handle Delta faucet that drips.  With both handles turned completely to off, the faucet drips at a about 1 drip every 15 seconds
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
Dec 15, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
HOW TO FIX DRIPPING
if it is dripping from the spout (where the water normally comes out) then you need to replace the cartridge or seals that are under the handle.
Oct 22, 2009 | Hansgrohe 32020001 Talis S Single-Hole...
Price Pfister Treviso Wide Lavatory Faucet T49-DK00 Logo
446 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
