Question about Intellitouch Audio Players & Recorders
I have a intellitouch guitar tuner. I turned it off,now I can't get it off the learn mode. Can you help? You don't have a category for guitar tuners!
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
  • 73 Answers
SOURCE: how to turn off an FM tuner mp3 player
Normaly with most generic MP3s you press and hold Stop or Pause. You got a make and model on this one?
Posted on Apr 22, 2009
  • 5603 Answers
SOURCE: tuner for my acoustic guitar no longer works
Change the battery again and make sure you get a fresh name brand battery.
SOME batteries that are off brand or old or just plain defective will cause your symptoms.
ALSO check that it is securely contacting the battery contacts.
Things thaat come on for a second MAY just be residual charge on the filter capacitors that a breif contact was made to the battery.
Posted on Oct 27, 2009
SOURCE: Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Posted on Mar 12, 2010
  • 5603 Answers
SOURCE: tuner
In the navigator display in the upper right corner of the face, after holding the tap switch or the tap footswitch for over two seconds the display will indicate your tuning. Strike an open string and the left end of the display will show you the note. Then there will be left and right arrows on the screen until you adjust your tuning for that note. When in tune for that note, two asterisks will be displayed in the center of that display.
Read your manual on the page with the "Smart FX" at the start.
Posted on May 15, 2010
What are some basic instruction for learn a acoustic guitar properly?
If you are gonna play acoustic guitar for first time then you have to choose different guitar.You should choose easy free string because it will help you to get tuned easily and there is matter with shaped of guitar.See here for first acoustic guitar epic guide line http://www.musicskanner.com/best-acoustic-guitars-2016-epic-guide/
Oct 30, 2016 | Music
I plug my guitar to the amplifier and i get no sound at all..... only if i press the tunning button turns on & stays on for couple of minutes and then it goes off again....what can i do? P.S.: The...
The tuner on this is weird. It requires three presses of the tune button. Read your manual... One press turns on tuner and passes audio till it times out. A second turns on tuner and kills audio... the third press restores audio... Others have had the same problem understanding this three mode thing and the timeout in the first two modes is confusing when sound disappears.
May 14, 2011 | Takamine EG340CLH Acoustic-Electric Guitar
I have no instructions. how do i use it? i want a detailed answer please.
Clamp it to the headstock of your guitar just like in the picture. Press the power button. Pluck one string on your guitar, the screen will light up with the corresponding note (standard tuning from largest string to smallest string is E A D G B E). The arrows will indicate whether the string is sharp or flat (too high or too low). More left arrows indicate that the string is too low, too many arrows on the left indicate that it is too high. Turn the tuning peg, slowly, on the corresponding string until you've got 6 solid arrows.
Here's a video
http://www.expotv.com/videos/reviews/16/154/IntellitouchPT1Tuner/275941
Dec 31, 2010 | IntelliTouch Communications Intellitouch...
My tuner reads D when it should be on E. It is set for 440. Please help. Thx
Test on another guitar first... If it only happens on yours, then you guitar MAY have a resonance in the neck or bridge that cross couples to your D string that MAY be the strongest vibration which the tuner is looking for. Try damping your D string while tuning the E strings by placing a finger on the D string to quiet the D..
Sep 19, 2010 | IntelliTouch Communications Intellitouch...
Jan 05, 2010 | Music
Dont know how to tune for the life of me
After plugging it into the tuner ... Play one string and watch the arrow ... If its not centre then gently turn the tuning key for that string on the guitar until it says its in tune ... do this for each string.
When your holding the guitar looking down at the strings ... the biggest one is E ... then from there its A,D,G,B,E.
Apr 04, 2009 | Elo Open Box D20786-000 INTELLITOUCH USB...
Durabrand wd810
Page 12 of the WD810 manual states: XM OPERATION =SWITCHING TO XM MODE Press MOD button (6) shortly to select XM mode. =SELECTING CHANNEL UP/DOWN Press the TUN/TR>> button (17) or TUN/TRK<< button (16) to select the channel up or down. = SM MODE SELECTION Press LOC/XM button (2) to switch Category mode, Skip mode or normal. It is used as the selection of each: Normal >> Category mode >> Direct Tune >> When Category mode or Skip mode is engaged, the "CATEGORY" function is turned on in the display. When Category mode or Skip mode is released, the "CATEGORY" function is turned off. When Direct mode is engaged, "DIRECT" of alphanumeric display is turned on. How to direct tune (omitted)
Dec 28, 2006 | Durabrand WD810
Top Intellitouch Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Intellitouch Audio Player and Recorder Expert? Answer questions, earn points and help others
