Question about ASUS P5AD2-E Premium Motherboard
My friend and I built this system with Asus p5ad2-e premium in 2005 I have (2) 74 gb sata hard drives. this is the fourth time the raid0 configuration has screwed up. I get either non-member or an error occured for one member, non-bootable or failed. I can't use ctrl I and select option 1 (create raid volume) to fix, although the system boots up. I just wonder why I have these problems with raid0 config plz help. thx, steve
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Posted on Jun 13, 2008
romeo_robu
  • 20 Answers
SOURCE: gigabyte ga-965p-ds3 signed raid driver
Windows 7 contain raid driver inside for almost all motherboards.
Posted on Apr 26, 2010
SOURCE: Unable to see RAID 5 config on Asus kfn32-D SLI/SAS MB
First IDE mode will not allow you to use RAID so you cannot use that. NVidia RAID should be able to handle the 2.72 TB RAID volume but there are other limitations you need to be aware of. . MBR which is Master Boot Record is the volume structure used by most windows systems and it has a limitation of 2 TB. You can use the newer GPT instead of MBR, but you cannot boot off of a GPT volume directly on most PC's. To do that you would need EFI (Extensible Firmware Interface) which basically is a new replacement for the BIOS. The motherboard manufacturer would have to support EFI.
You do have a lot of alternatives here though. Given the fact that you have four drives you could use one drive for the system disk, and use the other three for a RAID 5 volume. You would install windows on the single drive and then boot into windows and used disk manager to create a new partition on the RAID 5 volume. The benefit is read access speed and redundancy. There is a write performance hit because of parity generation and the space available for data is approximately the same as the total of 2 drives. The rest of the space stores the parity information. So you end up with 1 TB system drive with no redundancy, and a 2 TB RAID volume.
You could also use RAID 0+1 which is two stripe sets where one is a mirror of the other to provide redundancy. This gives you speed without the write performance hit. With 4 x 1 TB drives, you would end up with a bootable 2 TB volume with redundancy and excellent write and read performance.
Posted on Jul 20, 2010
Need all Asus P5ad-2 premium drivers
Search asus p5ad2 premium drivers. Choose Download. Then XP and download from Global. Unzip and runs setup. XP being the prominent OS of the day for this older unit.
http://www.asus.com/Motherboards/Intel_Socket_775/P5AD2_Premium/#download
http://support.asus.com/Download.aspx?SLanguage=en&m=P5AD2-E%20Premium&p=1&os=
Oct 22, 2012 | Intel RECERTIFIED: Asus P5AD2-PREMIUM...
My Asus P5AD2 mother board bios wont detect my Hard Drives or CD drives. I installed vista onto it and it worked. Then without warning it refused to start. Now it will not detect anything but the...
double check cable from the mainboard to your hardisk like IDE or SATA together with the power cord
just make sure if its fully inserted. boot up the the pc press delete to check UP THE BOIS IF THE HARDISK is connected.
let see how it works.....
Feb 05, 2011 | ASUS P5AD2-E Premium Motherboard
ASUS P5AD2-E Premium Motherboard usb boot option
Hi friend,
You need to change your motherboard setting in BIOS ...you should enable your usb option......then it will work...
Dec 25, 2009 | ASUS P5AD2-E Premium Motherboard
Seagate Baracuda 7200.7 in a RAID0 array has failed. On Drive diagnostics Drive test get error message "Drive Failed! Return Code 7". What is the drive error?
Hello mmincalgary:
This drive error code 7 means the controller board that controls the drive has failed, the board is located on the harddrive itself, Replacing this drive will solve your problem, unfortunely Segate has had many issues with this drive especially the SATA ver .7, 160GB versions..
Sep 26, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Want to add 2nd hard drive to vista64bit hombuilt.
In one system that I have seen this one, we had loaded optimized defaults. One item you could look at are the jumpers and the SATA ports if the connections are correct.
Jun 02, 2009 | Microsoft Windows Vista Home Premium with...
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
I need ASUS P5AD2-E Premium set-up CD
I would be happy to send you a copy if thats ok.
Oct 27, 2008 | Computers & Internet
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
ASUS P5AD2-E Premium Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
