www.sears.com/appliances-vacuums-floor-care-parts.../b-1020290 SearsSears has replacement parts for all of the top vacuum brands, so you'll be .... Hoover Canister Vacuum Cleaner Replacement Crevice Tool Attachment 38617017 .....vacuum bags and numerous attachments, your vacuum will have your floors ...
You have to replace the floor joists. This is accomplished with bottle jacks to raise the floor high enough to fit new floor joistsalong side of the old ones.
Its best left to somebody who is experienced in construction
Unfortunately you can't remove that foil, you will end up doing more damage to the liner. the only thing you can do is replace the liner. And it's a big job, if the manufacture makes a replacement part for your unit, and if they do it will be costly. Your warranty will not cover it.
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
