Question about Gateway Sb-4100-A PC Desktop
I want to install new memory and i just cant get this thing open!
  • Anonymous May 22, 2008
    Same problem: I can't find any clips or circles to press. I've worked on several computers in the past. This is the damn hardest case to open I've ever seen. Kudos and curses to Gateway engineers for creating a tamper resistant product. Any ideas anyone?
Pull the black clip on the back up
then use the little indented circles on each side and press in and pull up
once inside switch three green tabs to show red.... then lift up the back metal base up and it will pull away from the RAM area
Posted on May 19, 2008
    Problem Solver:
  • 23 Answers
Send or upload a picture of your computer and I will try to assist you; have you tried just looking in the back of the computer. typically there should be two screws and an indentation on the side panel to pull it back.
Posted on May 13, 2008
When turning on Sb-4100 I get message "unable to start driver for hpoipm07.exe". What to do?
Hi rbrown454. That file is for your HP printer. Go to hp.com and click on support and drivers and download the latest driver for your printer. While it's downloading go to add/remove programs in Control Panel and uninstall ALL HP software. Do not restart, wait for the software to finish downloading and restart. Then reinstall the software you downloaded from the internet.
In case you have the CD, reinstall the CD but make sure you uninstall ALL HP Software.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast/free support today. Thank you :D
May 10, 2010 | Gateway Sb-4100-A PC Desktop
I have intel desktop board D865GBF WITH INTEL PENTIUM 4 PROCESSOR PLEASE SUGGEST ME SOME ACCESSORY FOR UPGRADING MY PC PERFORMANCE AND QUALITY
You can start with the CPU. Here is a list of supported processors for your motherboard.
http://www.intel.com/support/motherboards/desktop/D865GBF/sb/CS-026966.htm
Then your RAM can be increased. See this page for approved/tested RAM modules:
http://www.intel.com/support/motherboards/desktop/D865GBF/sb/CS-027111.htm
If you should install 4 1GB modules, you will only show 3.5 if you use a 32-bit operating system.
The third thing you can do is to add or upgrade a video card. This board has an 8X AGP slot. It is compatible with 0.8V or 1.5V cards only. Install one with the greatest amount of memory you can afford. Suggest 512MB or 1GB.
Those are the main improvements you can make to this, or any board for that matter.
Good luck. Thanks for using Fixya.
Apr 01, 2010 | Computers & Internet
System wont boot up
operating system already corrupted, your need to re install your operating system from cd installer, you can keep your existing file by selecting no to format.
Mar 22, 2010 | Gateway Sb-4100-A PC Desktop
NO AUDIO ON MY SB-4100-A DESKTOP.
The reason to this problem is due to the audio driver.so you
need to install the audio driver.
Sep 02, 2009 | Gateway Sb-4100-A PC Desktop
Gateway e-4100 thermal event
There can also be thermal sensors in your power supply, on your motherboard, and video card. Does your problem happen during gaming/heavy computing, after x amount of time, or totally randomly?
If your case conforms to the later ATX spec or some derivative thereof, don't block the hole in the side of the case.
Just some stuff I've run into, maybe you already know this!
Nov 25, 2008 | Gateway Sb-4100-A PC Desktop
How Do I Open The PC to Add Memory
Hi Elmiragez
In order to open the E-4000 chassis, you have to press a button that blends in with the rest of the system's front panel. Once open you will be able to get to memory and all. The button does blend in with the system's front panel.
Hope this is your answers your question an solves it?
Jun 08, 2008 | Gateway E-4100-F3 (E4100F3-D) PC Desktop
133hz sdram problem
Please check this Intel link that shows specifications for memory that can be used in the Intel D845WN motherboard.
http://www.intel.com/support/motherboards/desktop/d845wn/sb/cs-008941.htm#1
When upgrading or increasing memory. The DIMM's should be the same. The Intel D845WN board requires the memory to run at 3.3volt. If the memory you are adding is within the Intel spec's, than switch the two Dimm's. Insert only the new DIMM & check if the system hangs. If it does than it is possible the new memory it either not compatable or is defective. For more information about the D845WN board download the manual for you're Intel board. http://support.intel.com/support/motherboards/desktop/d845wn/sb/cs-008937.htm
Luck!
Mike
May 19, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Gateway E4100 Mid Tower RAM install
no need to install RAM in pairs.
you can buy and install memory but it should be the same model that you have now e.g. DDRII RAM Modules.
you can max out the RAM 4 gigs
Mar 30, 2008 | Gateway Sb-4100-A PC Desktop
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
Gateway Sb-4100-A PC Desktop Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
