Question about Acer Aspire 5050-3242 Notebook
Acer \r\nmy acer operating systen not found - Acer Aspire 5050-3242 Notebook
    Master:
  • 644 Answers
Check whether your harddisk is working fine. If it is, try reinstalling the operating system once more.
Posted on Oct 17, 2010
Hp 6930p nmi channel check iochk
System I/O address specifications 970-071 NMI enable/RTC
What is Nmi Error On Hp Server error? The Nmi Error On Hp is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
This code is used by the vendor to identify the error caused. This Nmi Error On Hp Server error code has a numeric error number and a technical description. In some cases the error may have more parameters in Nmi Error On Hp Server format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
What causes Nmi Error On Hp Server error? The Nmi Error On Hp may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Nmi Error On Hp Server error? There are two (2) ways to fix Nmi Error On Hp
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Nmi Error On Hp Server) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Dec 10, 2016 | HP Computers & Internet
Hard drive crash. Need Systen disks to restore
you can re install and format your drive directly. just boot on cd with your os and select bootmenu choose cdrom. and follow instruction
Jun 02, 2011 | Acer Computers & Internet
NMI ISSUED PRESS ESC TO TURN OFF NMI IN IBM SERVER
dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on http://www-947.ibm.com/support/entry/portal/docdisplay?brandind=5000008&lndocid=MIGR-5069937
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
May 07, 2010 | IBM eserver xSeries 360 8686
When I turn on my notebook, the screen come black with an error message, operating systen not found, what do I do?
That is a symptom of a failed harddrive.
Assuming the cables are connected correctly,
I would try to booting with a Windows CD to see if you can access the contents of the harddrive. If you can, copy your data off to an external drive before you begin diagnostics, reformatting or naything else.
Oct 26, 2009 | Computers & Internet
Did not get manual for my acer-aspire4720Z laptop 14'1 computer
http://www.nodevice.com/user_manual/acer/notebooks/aspire_47204320/download_3164097_323914.htmlthis where where it is online i guess i should have been more specific
i will send yhou an xps file of it so you can print it out,
is this what you need?
Apr 23, 2009 | Acer Aspire 4720 Notebook
Acer Aspire 5050-3242 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
