How do I take my Heatseal Proseries 4000Lm apart because a pouch has got stuck?
My feed tray is stuck. It is not in the correct position and there seems to be a little tab stuck on the left hand side. Help, please!
The pin on the left side is used to actuate a safety switch. It must be in the small hole or the machine will not power on. It is spring loaded, so pull it to the right to release the tray.
Aug 27, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Is there a schematic diagram for heatseal ultima 65 I need one.
not that I am aware of, the maint manual has a theory of operation block diagram, but no schematics.
Jan 28, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Reassemble after having to take apart?
did you get it fixed, I had the same problem but with a different part , I know where your part go's
1st without screw holes go's in the Rear where the laminate comes out and the next one goes on top email me if you didnt fix it yet , I can open mine and get pictures Email me here
scolt@tampabay.rr.com Subject Laminator APL-330U
Oct 22, 2014 | Royal Sovereign 13" APL-330U Hot & Cold...
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
. How do i fix my fellowes Mars A3 laminator it has jammed
Let it cool off for a while, then try reversing it. If it won't run it would have to be taken apart to clear the jam - a messy job! Fellowes does not usually consider these to be repairable but I would call them on their Toll-Free number to see what they can offer (800) 955-0959
Jul 01, 2014 | Gbc HeatSeal H425 Laminator
Please help!!! I put a pouch into my scotch TL901 laminater the wrong way and it is completely Jammed in the middle of the machine!!! I used a flashlight to see how bad it was ad it is completely shredded...
Unplug laminator. If it does not open up -check to see if the machine has a pouch jam lever. The lever will make it easier to remove the jammed pouch. Put the screw back after you clear the jam.
Jul 12, 2017 | Office Equipment & Supplies
Plastic tangled to roller not moving at all
I just had this problem. I let it cool but still let the rollers keep rolling. Take the roller cleaning cardboard thingy and listen for the now cooled tangled plastic pouch to click around the roller. AND reversing the rollers so I could see the stuck plastic. When I could see the plastic I let the reverse go back to normal rotation and put the cleaning cardboard through and it finally caught the plastic pouch and pushed it out! WOO HOO! SAVED MY MACHINE!!! MACHETE STYLE!
Aug 17, 2011 | Gbc HeatSeal H520 12.5-Inch Commercial...
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
I have a gbc heatseal h425 laminator and it wont turn on. Is there a fuse inside the machine that needs to be replaced
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Dec 23, 2010 | Gbc HeatSeal H425 Laminator
283 people viewed this question
jasbo
jasbo
